Rev Limiter As Soon As Powerband Hits, Need Help!
Do you mind sharing the explanation ?
well, you see, there is about 300-350 wraps per pole on the ignition winding, depending on manufaturer and wire size. i've seen where corners were cut to speed things allong, and the wraps were nit real organized, which they need to be to a certain degree, in order to make power... hell i even wrapped one of my first ones in somewhat of a hurry, and did it all over again after installing it to test.
hmm sont call me dumb for thinking this, could a slipping clutch cause that?
No, a slipping clutch will rev high and go no where.
The stator can provide good spark until a certain RPM and then fall off. It sounds like that could be your problem.
SP
