Man-O-Steele Posted June 28, 2011 Report Posted June 28, 2011 hi im new to banshees and the bike that i bought has a chozen performance head. i know a little bit about the prodesign and all that buti cant seem to find much about the chozen perfromance ones. can anybody tell me if they are any good or give me any links to where i can read about them online? Quote
bansheesandrider Posted June 28, 2011 Report Posted June 28, 2011 (edited) Last I heard Chozen Performance went out of business. I don't knowhere you can find any info on them. You can pull it off and see if the domes and o-rings are the same as Noss, Pro Design, Chariot, or some of the other ones. By the way, I would stay away from the Pro Design heads as you have to install longer studs in your cylinders to install it. Edited June 28, 2011 by bansheesandrider Quote
Man-O-Steele Posted June 29, 2011 Author Report Posted June 29, 2011 Last I heard Chozen Performance went out of business. I don't knowhere you can find any info on them. You can pull it off and see if the domes and o-rings are the same as Noss, Pro Design, Chariot, or some of the other ones. By the way, I would stay away from the Pro Design heads as you have to install longer studs in your cylinders to install it. fair enough i guess.. the motor was recently rebuilt before i bought it so ill just run it and see what happens from there.. then when or if it blows up ill look for something different.. thanks for the info Quote
