figuare9 Posted June 26, 2011 Report Posted June 26, 2011 (edited) Worth it? Thinking about purchasing a set, however I'm not sure if they'll be worth the money. Never used em, never ridden a shee with a set on them. Any thoughts? I would get the full works, cage included Edited June 26, 2011 by figuare9 Quote
prssantana Posted June 26, 2011 Report Posted June 26, 2011 I just picked up a set a few weeks ago to replace my stock ones that were warped. They made a huge differrence. A lot of guys use the chariot set up on smaller builds. Chariot says they make a few more horse then vf3s and they are a little cheaper. Btw the reeds and cages will only work with each other. Quote
jbooker82 Posted June 26, 2011 Report Posted June 26, 2011 I would run reeds desinged by a dedicated compnay that only does reeds. In other words Vforce. Quote
figuare9 Posted June 26, 2011 Author Report Posted June 26, 2011 (edited) Well I was thinking about Boyesen Power Reeds, or a stock replacement, and of course Vforce.. but what kind of differences will I see? noticeable? or just another company claiming bolt on hp. Like I said, I've never been able to witness the difference between stock/vforce reeds myself. I also heard that they wear fast.. How "Fast" is fast? What kind of life can I expect to get from them? Edited June 26, 2011 by figuare9 Quote
jbooker82 Posted June 26, 2011 Report Posted June 26, 2011 V force reeds have 2x as many reeds. So you have 2x as many reeds opening up Half as far. They should last longer and be more responsive. Quote
06specialedition Posted June 26, 2011 Report Posted June 26, 2011 I run V-Force 3's and have no complaints at all. Quote
jerzy609 Posted June 26, 2011 Report Posted June 26, 2011 i mostly noticed a big difference in throttle response!!! Quote
figuare9 Posted June 26, 2011 Author Report Posted June 26, 2011 Thanks for the replies. Last question.. I'm looking on ebay for these.. I find a bunch of vforce 3 delta "Packages" but I don't see any reed stops in them. . Are they just not including them? Do I need them as well? For instance here. http://cgi.ebay.com/ebaymotors/NIB-Yamaha-Banshee-V-Force-III-Reeds-Reed-Cages-Assemb-_W0QQcmdZViewItemQQhashZitem5192c32823QQitemZ350354614307QQptZMotorsQ5fATVQ5fPartsQ5fAccessories I also see others with the reed stops.. I'll be the first to admit I have NO idea what I'm doing with reeds. 4 stroke kinda guy. Recently got into the whole 2 stroke thing. Quote
DallasGDub Posted June 26, 2011 Report Posted June 26, 2011 The Banshee VF do not use reed stops. I think the pic you see on some of the listings are just a default pic and not the actual banshee model. Quote
dirtydownunder Posted June 27, 2011 Report Posted June 27, 2011 ive had mine for 3 years, in 3 different motors and they look just as good as when i put them in. they come with a cool sticker too.... x2 what jb82 says. Quote
patsbansh Posted June 27, 2011 Report Posted June 27, 2011 I absolutely swear by them. The last set i actually purchased from Patrs deopt on ebay. On my stock shee i have FMF pipes virgin cylinders with wiseco pistons, cool head w 22 cc domes, V Force 3's and a timing advance and i smoke all my buddies with boysen or stocks and they have bore jobs oversize pistons and the same pipes. i also run them on my asphalt shee with a 421 cub motor. Quote
figuare9 Posted June 27, 2011 Author Report Posted June 27, 2011 The Banshee VF do not use reed stops. I think the pic you see on some of the listings are just a default pic and not the actual banshee model. Thanks. Just because I'm curious, do you know why they don't use the reed stops? The stock reeds do, why not the VF 3? Also, you guys have me set. Ordering them on Friday. Thanks Quote
05Twin350 Posted June 27, 2011 Report Posted June 27, 2011 I love my set of VF3's. Can't go wrong with them! Quote
fastquad02blaster Posted June 28, 2011 Report Posted June 28, 2011 i mostly noticed a big difference in throttle response!!! Plus one on this one. It's pretty snappy now for sure. Vforce3s don't have any stops. I'm thinking that the actual cage will flow better than stock. This adds some power. So you're getting some power and amazing throttle response. Worth the money to me. Quote
