LS3 Machine Posted June 26, 2011 Report Share Posted June 26, 2011 I bought a kit with LSR A Arms, +2/+1 kit and Elka shocks, and Im starting the install process. There were no instructions with the kit, and the guide on LSR just covers setting the alignment after the install is complete. It seems pretty straight forward with one exception- What side do the upper arms go on? I have the bottom Arms figured out using the LSR logos as a guide, but Im not sure which upper goes on which side? The bags they came in were not labeled. Should the Arm appear arched upwards, like a hill? or sagging in the middle, like a valley? The arms seem identical, but I could be wrong. I guess a better way to ask, is on the upper A Arms, I guess the grease fitting goes on the top (just like on the bottom A Arm)? Thanks, Tim Quote Link to comment Share on other sites More sharing options...
LS3 Machine Posted June 26, 2011 Author Report Share Posted June 26, 2011 I bought a kit with LSR A Arms, +2/+1 kit and Elka shocks, and Im starting the install process. There were no instructions with the kit, and the guide on LSR just covers setting the alignment after the install is complete. It seems pretty straight forward with one exception- What side do the upper arms go on? I have the bottom Arms figured out using the LSR logos as a guide, but Im not sure which upper goes on which side? The bags they came in were not labeled. Should the Arm appear arched upwards, like a hill? or sagging in the middle, like a valley? The arms seem identical, but I could be wrong. I guess a better way to ask, is on the upper A Arms, I guess the grease fitting goes on the top (just like on the bottom A Arm)? Thanks, Tim Ok thru internet research, and just common sense, Im 99.9% sure I have it figured out. If anyone here can 100% confirm the upper A arm looks correctly mounted in these pics, I would appreciate it. Quote Link to comment Share on other sites More sharing options...
Zwiser Posted June 26, 2011 Report Share Posted June 26, 2011 thats right... Quote Link to comment Share on other sites More sharing options...
LS3 Machine Posted June 27, 2011 Author Report Share Posted June 27, 2011 thats right... Thanks man, Just good to have confirmation since I don't have directions, and I'm new to the Banshee world. Quote Link to comment Share on other sites More sharing options...
