Fearnot Posted June 25, 2011 Report Share Posted June 25, 2011 I have a set of PT mid's and the fat boy 2 muffler pipes are rubbing the air filters. The filters are 15 degree angled and still rub along the pipes. Is there an airbox set up or someway for me to get protection to this engine? Thanks for your time. Quote Link to comment Share on other sites More sharing options...
bansheesrtoys Posted June 25, 2011 Report Share Posted June 25, 2011 i had the same problem with my toomey 2:1 air filter. i put exhuast wrap and sprayed with high temp siicon spray only where the filters rubbed. worked great. or cascadeinnovations sells exhaust sleeves for this problem. cost more than the exhuast wrap but looks nicer. Quote Link to comment Share on other sites More sharing options...
06specialedition Posted June 25, 2011 Report Share Posted June 25, 2011 X2. Try some exhaust wraps to prevent melting your filters. Here ya go: http://67.199.65.66/cascade_innovations/newlook/store/store_view.cfm?store_area_id=13&STORE_DEPT_ID=168 Quote Link to comment Share on other sites More sharing options...
Fearnot Posted June 25, 2011 Author Report Share Posted June 25, 2011 Thanks both you guys, can't believe I didn't think of it. Quote Link to comment Share on other sites More sharing options...
camatv Posted June 26, 2011 Report Share Posted June 26, 2011 modify'd stock airbox works great. or make your own. or get the big ass sleeve's Quote Link to comment Share on other sites More sharing options...
Fearnot Posted June 26, 2011 Author Report Share Posted June 26, 2011 modify'd stock airbox works great. or make your own. or get the big ass sleeve's I was thinking about going back to the stock airbox do you know where I can find carb boots for 33mm pwk's to the airbox? Also I'm running 165main's 50 pilots with K&N pods how much would I have to jet down? Quote Link to comment Share on other sites More sharing options...
Fearnot Posted June 27, 2011 Author Report Share Posted June 27, 2011 Stock airbox looks like a no go also. Any idea's guys? Sorry about the shitty camera. Quote Link to comment Share on other sites More sharing options...
springer Posted June 27, 2011 Report Share Posted June 27, 2011 i had the same problem with my t-5's back in the day. i just put a hose clamp around the pipe and frame where you couldn't see it and pulled the pipe right up next to the frame. just put something around the pipes so it wont scratch them. worked great for me, and cheap. Quote Link to comment Share on other sites More sharing options...
Fearnot Posted June 27, 2011 Author Report Share Posted June 27, 2011 i had the same problem with my t-5's back in the day. i just put a hose clamp around the pipe and frame where you couldn't see it and pulled the pipe right up next to the frame. just put something around the pipes so it wont scratch them. worked great for me, and cheap. Well you see my problem with the fatboy 2 mufflers is the mounting tabs they use don't allow them to pulled any closer to the frame rails. Also with how far back the boss intake set the carbs the airbox is touching the carb bells and isn't even close to being mounted. Is there a different make of mufflers that fit the PT mid ranges and mount closer to the frame rails? I need spark arrested mufflers soon anyways. Quote Link to comment Share on other sites More sharing options...
