BrockMoto Posted June 24, 2011 Report Share Posted June 24, 2011 first I know its bad I am replacing everything thats why its apart but new parts don't exactly fix the issue... need to know why left right and plugs and also one of the nuts on the cylinders is rounded.. How can I get it off and what is the best option to replace thanks guys!!! Quote Link to comment Share on other sites More sharing options...
BrockMoto Posted June 24, 2011 Author Report Share Posted June 24, 2011 also when i took the left cylinder off (right is still on because of nut mentioned in previous post) there was small amounts of what looked like oil.... any thoughts? Quote Link to comment Share on other sites More sharing options...
crash&burn Posted June 24, 2011 Report Share Posted June 24, 2011 For the stripped nut part depends on which one it is. they make easy out things for stripped nuts or you could cut the nut just before you hit the threads and it should come off then and i know Craftsman makes sockets that go on i think 8 diffrents heads of bolts and nuts and and they work well for stripped nuts and bolts if you can pound one on i have done it before and work really well Quote Link to comment Share on other sites More sharing options...
BigRed350x Posted June 24, 2011 Report Share Posted June 24, 2011 One piston you are lean and the other you are rich. The piston with almost no carbon buildup is rich. That's called piston wash. You have so much fresh fuel coming into the cylinder that it washes the top of the piston. The other cylinder looks lean and like you might have some detonation or you got some crud into the engine somewhere. Did you do a leak-down test? Take your carbs and clean the crap out of them and make sure both are jetted correctly and adjusted properly when you put it back together. Pull your jets out and clean behind them in the carbs. Quote Link to comment Share on other sites More sharing options...
BrockMoto Posted June 24, 2011 Author Report Share Posted June 24, 2011 will do with the carbs... I didn't do leak down was afraid it was an airleak so I planned to replace crank seals but the closer i get the more nervous the bottom end makes me lol why would it differ in each cylinder like that? and looks like I may need that motor more than i though big red!!! lol Quote Link to comment Share on other sites More sharing options...
Larry's Shee Posted June 24, 2011 Report Share Posted June 24, 2011 Is that all carbon built up on the right piston? Quote Link to comment Share on other sites More sharing options...
BrockMoto Posted June 24, 2011 Author Report Share Posted June 24, 2011 Not sure... Just black crap... There are dings and dents on top of the pistons too.. U can see in the pics... Wth Quote Link to comment Share on other sites More sharing options...
Fastassbanshee96 Posted June 24, 2011 Report Share Posted June 24, 2011 Is your choke tube hooked up on your carbs? If not that will lean out your right cylinder real bad. Quote Link to comment Share on other sites More sharing options...
J-Madd Posted June 24, 2011 Report Share Posted June 24, 2011 What does the head look like? It's ALWAYS a good idea to pressure test before tearing down after a failure. That way you know if and where it was leaking. Now you won't know for sure, though it does appear to be an air leak. We've all made the mistake of hastily tearing them apart without pressure testing, though. Quote Link to comment Share on other sites More sharing options...
BrockMoto Posted June 24, 2011 Author Report Share Posted June 24, 2011 Is there a list of possible areas so I can fix em all or could it be any thing Quote Link to comment Share on other sites More sharing options...
camatv Posted June 24, 2011 Report Share Posted June 24, 2011 pressure test before teardown? i would say that motor will need a crank seems crak failure is causing som problems proper part replacement and proper rebuild techniques should result in good running well sealed motor.. Quote Link to comment Share on other sites More sharing options...
BrockMoto Posted June 24, 2011 Author Report Share Posted June 24, 2011 How can I check the crank cam Quote Link to comment Share on other sites More sharing options...
