252wheelieking Posted June 18, 2011 Report Share Posted June 18, 2011 How do I recognize a Cheetah Cub from a CUB? What to look for? Quote Link to comment Share on other sites More sharing options...
NYUK Posted June 18, 2011 Report Share Posted June 18, 2011 huh? Quote Link to comment Share on other sites More sharing options...
dirtydownunder Posted June 18, 2011 Report Share Posted June 18, 2011 cheetah runs bigger reeds (250cc reeds) cheetah cub runs stock reeds Quote Link to comment Share on other sites More sharing options...
252wheelieking Posted June 18, 2011 Author Report Share Posted June 18, 2011 (edited) So there is NOT a such thing as a straight cheetah? There is only a cheetah cub, super cub & regular cub. I was thinking that they made a cheetah, cheetah super cub & cheetah cub....I'm thinking they all had the first name of cheetah. Edited June 18, 2011 by 252wheelieking Quote Link to comment Share on other sites More sharing options...
tedd1 Posted June 18, 2011 Report Share Posted June 18, 2011 CP Industries Quote Link to comment Share on other sites More sharing options...
NYUK Posted June 18, 2011 Report Share Posted June 18, 2011 yes there is king, larger, takes a different head. different reeds. Quote Link to comment Share on other sites More sharing options...
camatv Posted June 18, 2011 Report Share Posted June 18, 2011 cheeta was the first cylinder for the banshee from cp industries. cheeta is optinal with power valves, a modern head with modern stud spacing for mucho better head seal, 250r reeds , and much simpler o-ring design, they are also very wide at the base and most all of them require top case filling for any kind of port matching. used to be they were available in 65mm all the way to 75mm bore and stock stroke to 16mm stroke. they are not as popular because of the cost of them. in my OPINION they are the best cylinder overall for the banshee available. they can produce low end like a serval with top end like a cub. they dont have as much issue with head sealing as a cub or super cub Quote Link to comment Share on other sites More sharing options...
beebs Posted June 19, 2011 Report Share Posted June 19, 2011 Does the cub and super cub have head sealing issues? I have only read about the cheeta with head o-ring eating issues? Quote Link to comment Share on other sites More sharing options...
camatv Posted June 19, 2011 Report Share Posted June 19, 2011 welp the truth is you run a squish like an oem cylinder can handle and a cub and super cub will warp the head and eat the o-rings and probably blow the motor up. this problem has been kinda fixed with really loose squish band (48 tho and up) and a really reinforced head for the super cub.. the cheetas never had a o-ring issue. some did have similar dome learning curve problems that resulted in dome issue's my 2 cheetas have had the same comp o-rings in them for the last 5 years.. the problem is not as likey to happen IF you are carefull with the build using a proper head on super cubs, strong studs on both, and proper dome setups is really the key to them survivng. its just for the $$$ you should really consider all yoru options it is hard to chose a cylinder these days.. at least with all the CP industies stuff available. and others like twister, la/sleeve/ESR, t-rex, and vito's out there.. BUT even with those issues i'd still consider a cub, or cheeta, or wompus cylinder to be at the top of the list. Quote Link to comment Share on other sites More sharing options...
