eldreder Posted June 18, 2011 Report Share Posted June 18, 2011 i was putting my case back together and realized that hole number 15 is stripped, i've heard of a few things i could do to fix it, the best being probably drill out to the next size, or use a helicoil, what's your ideas? Quote Link to comment Share on other sites More sharing options...
dirtydownunder Posted June 18, 2011 Report Share Posted June 18, 2011 id helicoil it. Quote Link to comment Share on other sites More sharing options...
bansheesandrider Posted June 18, 2011 Report Share Posted June 18, 2011 I would Heli-Coil it, there may not be enough meat there to adequately support the next size bigger bolt. If it is helicoiled, it will still use a stock bolt and the same size wrench as the other bolts. It is not hard to do and done right it will be stronger than the original hole because the bolt threads will now be turning in steel instead of aluminum. Quote Link to comment Share on other sites More sharing options...
jlsparky7 Posted June 18, 2011 Report Share Posted June 18, 2011 I agree ^ Quote Link to comment Share on other sites More sharing options...
eldreder Posted June 18, 2011 Author Report Share Posted June 18, 2011 thanks for the input guys, i was pretty skeptical about the helicoil haha. i'll definitely go for it tomorrow though and post my results Quote Link to comment Share on other sites More sharing options...
eldreder Posted June 19, 2011 Author Report Share Posted June 19, 2011 i drilled it out and put the helicoil in, the bolt threads in and out without pulling the coil out, i'm gonna put the cases together and torque the bolts soon, i'm pretty confident it'll be good Quote Link to comment Share on other sites More sharing options...
spurdy Posted June 21, 2011 Report Share Posted June 21, 2011 Actually, especially for the cases, I would steer clear of a helicoil for thread repair. They are ok in a pinch but they are the most inadeguate thread repair components out there. If there is enough meat around the original hole to drill it out for a Keen Sert that is what I would use. It is a solid insert instead of just a *spring*. Anouther nice thing about them is the outside thread is also a common metric size so there is no need for a special tap. They come in diferent styles. The one I like has tabs at the top that you drive in flush after it is installed and it prevents the insert from coming back out. We use these in manufacturing aluminum parts were threaded holes are needed for frequently removed items. SP Quote Link to comment Share on other sites More sharing options...
