roesso Posted June 11, 2011 Report Share Posted June 11, 2011 How hard is it to paint a frame with a spray gun? Never used one before, does anyone have any pointers or a first timer? Quote Link to comment Share on other sites More sharing options...
steady Posted June 12, 2011 Report Share Posted June 12, 2011 I thought about painting mine, but going powdercoat shouldnt ever have to touch it up. I figure painting it would be pretty hard, unless you have a way to get all the old paint off. Quote Link to comment Share on other sites More sharing options...
MDalton Posted June 14, 2011 Report Share Posted June 14, 2011 I thought about painting mine, but going powdercoat shouldnt ever have to touch it up. I figure painting it would be pretty hard, unless you have a way to get all the old paint off. Aircraft stripper while nasty, will take all the paint off. Quote Link to comment Share on other sites More sharing options...
vifferman Posted June 14, 2011 Report Share Posted June 14, 2011 As with most things the prep is the hardest part. If you skimp on the prep the paint will chip and peel off quickly. I've had two frames powdercoated and wouldn't do it any other way! It's WAY worth the $. They look incredible and are much more durable than rattle can. Quote Link to comment Share on other sites More sharing options...
steady Posted June 15, 2011 Report Share Posted June 15, 2011 just got mine back from powdercoater .... Quote Link to comment Share on other sites More sharing options...
vifferman Posted June 15, 2011 Report Share Posted June 15, 2011 Looks good steady, what color is the swingarm? Quote Link to comment Share on other sites More sharing options...
steady Posted June 15, 2011 Report Share Posted June 15, 2011 Looks good steady, what color is the swingarm? dormant blue with a coat of clear...6-7mil thick... Quote Link to comment Share on other sites More sharing options...
toytech Posted June 15, 2011 Report Share Posted June 15, 2011 just got mine back from powdercoater .... awsome color!!! is it getting blue plastic also? Quote Link to comment Share on other sites More sharing options...
steady Posted June 16, 2011 Report Share Posted June 16, 2011 its getting metallic silver plastics with same color blue transparent flames.... Quote Link to comment Share on other sites More sharing options...
toytech Posted June 18, 2011 Report Share Posted June 18, 2011 its getting metallic silver plastics with same color blue transparent flames.... that will look sweet Quote Link to comment Share on other sites More sharing options...
#1BADASSBANSHEE Posted June 30, 2011 Report Share Posted June 30, 2011 that will look sweet GET IT BLASTED THE ONLY WAY TO GO. ITS NOT HARD TO PAINT TRY IT ON SOMETHING ELS FIRST JUST TO GET THE HANG OF IT. I DID MINE BUT I WORK FOR A PAINT MANUFACTURE. SO I SPRAY ALL THE TIME. Quote Link to comment Share on other sites More sharing options...
DirtDiggler69 Posted August 13, 2011 Report Share Posted August 13, 2011 I'm painting my shee , flat black , painting takes a lot of time , just when you think youve got the frame covered , you see it from a different angle . Krylon fusion paint is what I'm using , it's great paint , has a epoxy based primer and adheres great . Excellent elastomer properties as well , stays very flexible . Quote Link to comment Share on other sites More sharing options...
Man-O-Steele Posted August 22, 2011 Report Share Posted August 22, 2011 from personal experience take your time and have it powdercoated. paint failing is the reason you want redo it to begin with. trust me bud its worth it. http://bansheehq.com/forums/index.php?showtopic=144733&st=0&p=1248204&fromsearch=1entry1248204 Quote Link to comment Share on other sites More sharing options...
Bkm2006 Posted August 23, 2011 Report Share Posted August 23, 2011 I prepped my frame for 5 hrs and then primed painted . Took a step back and decided to just get it powdered. Best thing I have ever done. Quote Link to comment Share on other sites More sharing options...
Man-O-Steele Posted August 23, 2011 Report Share Posted August 23, 2011 post some pics up im curious to see Quote Link to comment Share on other sites More sharing options...
