421alkybanshee Posted June 11, 2011 Report Share Posted June 11, 2011 I just purchased a set of cases from a guy in detroit, Is there any way to tell if the cases are a matched set and not a couple different motors put together? Quote Link to comment Share on other sites More sharing options...
NYUK Posted June 11, 2011 Report Share Posted June 11, 2011 yes, theres a hand engraved code to the right of the rear motor mount on the cases, same letters and numbers should be on the top and bottom. Quote Link to comment Share on other sites More sharing options...
dirtydownunder Posted June 11, 2011 Report Share Posted June 11, 2011 yes, theres a hand engraved code to the right of the rear motor mount on the cases, same letters and numbers should be on the top and bottom. is that, what that is hhaha. Quote Link to comment Share on other sites More sharing options...
421alkybanshee Posted June 11, 2011 Author Report Share Posted June 11, 2011 Thank you Quote Link to comment Share on other sites More sharing options...
BigRed350x Posted June 11, 2011 Report Share Posted June 11, 2011 You can almost always notice little variances on the stator side where they machine the outside edge of the cases for the stator cover as well. The matched sets line up damn near perfect, the un-matched sets never line up perfect. - Jared Quote Link to comment Share on other sites More sharing options...
Burt Reynolds Posted June 11, 2011 Report Share Posted June 11, 2011 Not to get to off topic but the old lt250r-trx250r middle split cases can be a nightmare if they are mis matched Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted June 11, 2011 Report Share Posted June 11, 2011 I would never run mismatched cases. Quote Link to comment Share on other sites More sharing options...
NYUK Posted June 11, 2011 Report Share Posted June 11, 2011 I would never run mismatched cases. its a crap shoot. i wouldn t either. Quote Link to comment Share on other sites More sharing options...
BigRed350x Posted June 12, 2011 Report Share Posted June 12, 2011 I've run them. Never had any problems. But I've heard of people who have had crank and trans failures due to the bearing to case clearances. - Jared Quote Link to comment Share on other sites More sharing options...
