Banshee starts but won't stay idle
Ok guys so I cleaned my carbs recently but still when I start the bike it has trouble starting n when it does if your not giving it gas it just dies....I know it's a prob something stupid but I dnt hav the time to b out there diagnosing it thanks for the help
Well I would check the choke tube is on the cards, check the slides are in right way with cut facing the air filters, last is to check the float bowl are on the right carbs.
its a little tube about 3 inches long . it is located between the two carbs about half way down the carbs . it links the chokes on the carbs together . if u dont have the choke tube ur bike will not run right if at all . do u still have the tors ?
