98MonsterShee Posted June 8, 2011 Report Share Posted June 8, 2011 Ok guys so I cleaned my carbs recently but still when I start the bike it has trouble starting n when it does if your not giving it gas it just dies....I know it's a prob something stupid but I dnt hav the time to b out there diagnosing it thanks for the help Quote Link to comment Share on other sites More sharing options...
Duneman101 Posted June 8, 2011 Report Share Posted June 8, 2011 make sure the half moon cut outs on the slide are facing towards the air filters... also make sure you reattached the choke tube that goes between the two carbs. Quote Link to comment Share on other sites More sharing options...
wfobasheeboy Posted June 8, 2011 Report Share Posted June 8, 2011 Ok guys so I cleaned my carbs recently but still when I start the bike it has trouble starting n when it does if your not giving it gas it just dies....I know it's a prob something stupid but I dnt hav the time to b out there diagnosing it thanks for the help Well I would check the choke tube is on the cards, check the slides are in right way with cut facing the air filters, last is to check the float bowl are on the right carbs. Quote Link to comment Share on other sites More sharing options...
98MonsterShee Posted June 8, 2011 Author Report Share Posted June 8, 2011 The slides are in right the bowls are on the right side I did a carb at a time, it wasn't even Startin before I cleaned the ccarbs, Quote Link to comment Share on other sites More sharing options...
wfobasheeboy Posted June 8, 2011 Report Share Posted June 8, 2011 The slides are in right the bowls are on the right side I did a carb at a time, it wasn't even Startin before I cleaned the ccarbs, choke tube from carb to carb ????? Quote Link to comment Share on other sites More sharing options...
mongo Posted June 9, 2011 Report Share Posted June 9, 2011 its a little tube about 3 inches long . it is located between the two carbs about half way down the carbs . it links the chokes on the carbs together . if u dont have the choke tube ur bike will not run right if at all . do u still have the tors ? Quote Link to comment Share on other sites More sharing options...
98MonsterShee Posted June 9, 2011 Author Report Share Posted June 9, 2011 Yea I still hav the tors on Quote Link to comment Share on other sites More sharing options...
