jon321 Posted June 5, 2011 Report Share Posted June 5, 2011 Wow thems were some big ass spacers in there now when I look at it. Before - WTF? After - Ahhh much better! Quote Link to comment Share on other sites More sharing options...
zach15 Posted June 5, 2011 Report Share Posted June 5, 2011 idk why people put reed spacers on it doesnt make it run better,ive had to put 3/4inch spacers for my carbs to clear the clutch arm but thats the only reason Quote Link to comment Share on other sites More sharing options...
SAVAGE420 Posted June 5, 2011 Report Share Posted June 5, 2011 Same here, only reason i put the 3/8 spacers on was to clear the clutch actuator arm with my DAJ fuel line at the bottom of the nut. http://i27.photobucket.com/albums/c164/savage_420/Carbs002.jpg Quote Link to comment Share on other sites More sharing options...
shanYE west Posted June 5, 2011 Report Share Posted June 5, 2011 the reed spacer is supposed to go between the carb and cage.. otherwise it affects your case volume. Quote Link to comment Share on other sites More sharing options...
278 Posted June 5, 2011 Report Share Posted June 5, 2011 Nice Saigas in your sig picture bro Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted June 5, 2011 Report Share Posted June 5, 2011 (edited) the reed spacer is supposed to go between the carb and cage.. otherwise it affects your case volume. Then wouldnt it be a carb spacer? You would also have a small carb boot opening dumping in to a large square opening, then going back in to a smaller opening of the reed cage. That would cause a lot of turbulance and have a negative affect on flow. I would leave them like that my self. Edited June 5, 2011 by jbooker82 Quote Link to comment Share on other sites More sharing options...
shanYE west Posted June 5, 2011 Report Share Posted June 5, 2011 Then wouldnt it be a carb spacer? You would also have a small carb boot opening dumping in to a large square opening, then going back in to a smaller opening of the reed cage. That would cause a lot of turbulance and have a negative affect on flow. I would leave them like that my self. Either way your fucked with a spacer.. By increasing case volume your slowing down the internal velocites of the fuel charge. Which will also give you a negative affect on flow. . Pic your poison. I'd just throw them out and bend the actuator arm down a bit. The only thing they're good for anyways is clearing the arm.. Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted June 5, 2011 Report Share Posted June 5, 2011 I just bend the clutch arm down. Quote Link to comment Share on other sites More sharing options...
06specialedition Posted June 5, 2011 Report Share Posted June 5, 2011 angled intakes Quote Link to comment Share on other sites More sharing options...
crustydemon Posted June 5, 2011 Report Share Posted June 5, 2011 angled intakes X2 Quote Link to comment Share on other sites More sharing options...
zach15 Posted June 6, 2011 Report Share Posted June 6, 2011 Either way your fucked with a spacer.. By increasing case volume your slowing down the internal velocites of the fuel charge. Which will also give you a negative affect on flow. . Pic your poison. I'd just throw them out and bend the actuator arm down a bit. The only thing they're good for anyways is clearing the arm.. I have traid that but i have tm34 flat slides on it an idk if u have every seen them but for some reason the bowl is giant and it still hits the arm but i know what your saying.I like them because i can make the spacers and people buy them ha Quote Link to comment Share on other sites More sharing options...
shanYE west Posted June 6, 2011 Report Share Posted June 6, 2011 best bet is the billet intakes with built in spacers. Quote Link to comment Share on other sites More sharing options...
camatv Posted June 7, 2011 Report Share Posted June 7, 2011 (edited) good, better, best, intake is a properly angled one that fits like it should.. no spacers.. tm's are really tall carbs/. if you can make the reed spacer you should be able to make your own alluminum intake. Edited June 7, 2011 by camatv Quote Link to comment Share on other sites More sharing options...
