acroadam Posted June 8, 2011 Author Report Share Posted June 8, 2011 I'm all for shortcuts, but no way in hell would I put a new seal in there without the cases apart. Yamabond won't fix the seal. It may be leaking around the inside of the seal, which is exposed to the moving crankshaft. Also, leaking around the key-way usually won't leak bad enough to do what you describe. How will I know if it's the crankshaft seal? Quote Link to comment Share on other sites More sharing options...
Jereme6655 Posted June 8, 2011 Report Share Posted June 8, 2011 while doing a leakdown test just spray the crank with a little soapy water.....you will see it if it IS the problem. Quote Link to comment Share on other sites More sharing options...
