coryv4 Posted May 29, 2011 Report Share Posted May 29, 2011 i am looking for a 4mil stroker long or short rod doesnt matter i would appreciate it if the main bearings are still good. thanks Quote Link to comment Share on other sites More sharing options...
methyman Posted May 29, 2011 Report Share Posted May 29, 2011 i am looking for a 4mil stroker long or short rod doesnt matter i would appreciate it if the main bearings are still good. thanks I have a used Hot Rod 4mm stroker long rod with max load bearing on flywheel side and tz on out put side for $320 shipped. Quote Link to comment Share on other sites More sharing options...
coryv4 Posted May 30, 2011 Author Report Share Posted May 30, 2011 I have a used Hot Rod 4mm stroker long rod with max load bearing on flywheel side and tz on out put side for $320 shipped. will these bearings work in a stock case Quote Link to comment Share on other sites More sharing options...
methyman Posted May 31, 2011 Report Share Posted May 31, 2011 will these bearings work in a stock case Yes. Better bearings than stock. Max load is 10 bearings instead of 8 being stock, The TZ is a flat roller bearing. Which is on all my cranks. Quote Link to comment Share on other sites More sharing options...
methyman Posted May 31, 2011 Report Share Posted May 31, 2011 You can get a new one from M&M ATV http://www.mmatvonline.com/product_info.php?cPath=26_27_22&products_id=33 Quote Link to comment Share on other sites More sharing options...
