BLK'N'YELLOW Posted May 28, 2011 Report Share Posted May 28, 2011 1997 banshee , bought it from a guy said it was built by richards atv, milled head, ported, welded crank b/b , t-5 pipes and mufflers, barnett clutch , trinity 2 into 1 intake 35mm carb 280 main i think , 180psi comp , ran on straight vp110 32to1 w/ klothz how much HP does that sound like, thanks when i go from 1200ft to 7000ft how many jet sizes should i drop down on the 2into1 carb set up , ? thanks guys Quote Link to comment Share on other sites More sharing options...
spurdy Posted May 28, 2011 Report Share Posted May 28, 2011 HP questions usually generate a plethora of not so nice responses. Some will have an opinion but most will be guesses at best. Porting can vary widely and the biggest HP gain is proper tuning on any given set up. If you really are interested in HP numbers, throw it on a dyno, and even still you'll have a guess at best since dynos can vary in their numbers depending on several factors. SP Quote Link to comment Share on other sites More sharing options...
shee4speed Posted May 28, 2011 Report Share Posted May 28, 2011 no answer on the hp. i usually drop 3 jet sizes going from phx to flag. that goes for my Banshee and Blasters. Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted May 28, 2011 Report Share Posted May 28, 2011 (edited) I was going to guess negative 10 due to the 2:1 carb. Edited May 28, 2011 by jbooker82 Quote Link to comment Share on other sites More sharing options...
BLK'N'YELLOW Posted May 28, 2011 Author Report Share Posted May 28, 2011 ok so i think its a 280 main go down to a 265 main for up north , ? 2-1 carb works great, i smoke my buddies with dual 30's with motor work , but then again there is so many factors, i was told i should have 59 or 69 hp the guy i bought it from didnt know, he said labor alone was 1700 if 2 into 1 slows u down i would hate to throw a dual carb set up on here , i cant keep it straight or on 4 wheels now Quote Link to comment Share on other sites More sharing options...
BLK'N'YELLOW Posted May 28, 2011 Author Report Share Posted May 28, 2011 HP questions usually generate a plethora of not so nice responses. Some will have an opinion but most will be guesses at best. Porting can vary widely and the biggest HP gain is proper tuning on any given set up. If you really are interested in HP numbers, throw it on a dyno, and even still you'll have a guess at best since dynos can vary in their numbers depending on several factors. SP thx brotha , i figured so , im all over the rhino forums so i know how it goes, lol Quote Link to comment Share on other sites More sharing options...
BLK'N'YELLOW Posted May 28, 2011 Author Report Share Posted May 28, 2011 I was going to guess negative 10 due to the 2:1 carb. LOL Quote Link to comment Share on other sites More sharing options...
shee4speed Posted May 28, 2011 Report Share Posted May 28, 2011 (edited) ok so i think its a 280 main go down to a 265 main for up north , ? 2-1 carb works great, i smoke my buddies with dual 30's with motor work , but then again there is so many factors, i was told i should have 59 or 69 hp the guy i bought it from didnt know, he said labor alone was 1700 if 2 into 1 slows u down i would hate to throw a dual carb set up on here , i cant keep it straight or on 4 wheels now start there, bring some extras down to 250. I ran 310's and dropped to 280's with stock carbs. I haven't ridden up there since I installed my 35's. Edited May 28, 2011 by shee4speed Quote Link to comment Share on other sites More sharing options...
camatv Posted May 31, 2011 Report Share Posted May 31, 2011 i project about 10-70hp at least in that range for sure.. Quote Link to comment Share on other sites More sharing options...
lms1977 Posted June 1, 2011 Report Share Posted June 1, 2011 I would say mid 50's to mid 60's Quote Link to comment Share on other sites More sharing options...
BLK'N'YELLOW Posted June 1, 2011 Author Report Share Posted June 1, 2011 I would say mid 50's to mid 60's what kinda gas u run and whats ur compression ? thx Quote Link to comment Share on other sites More sharing options...
dirtydownunder Posted June 2, 2011 Report Share Posted June 2, 2011 what does it matter ? did one of ya buds put a figure on one of their bikes ? throw it on a dyno, it could be running like ass and only making 13.6hp. the dyno could be wrong and you might make 100hp. dyno's are just as shit as people guessing hp. drag times dont lie tho. Quote Link to comment Share on other sites More sharing options...
lms1977 Posted June 2, 2011 Report Share Posted June 2, 2011 I run 110 octane straight or mixed with pump and about 180 or 185 on the compression Quote Link to comment Share on other sites More sharing options...
BLK'N'YELLOW Posted June 2, 2011 Author Report Share Posted June 2, 2011 (edited) what does it matter ? did one of ya buds put a figure on one of their bikes ? throw it on a dyno, it could be running like ass and only making 13.6hp. the dyno could be wrong and you might make 100hp. dyno's are just as shit as people guessing hp. drag times dont lie tho. whats ur drag time sweet cheeks , lol Edited June 2, 2011 by BLK'N'YELLOW Quote Link to comment Share on other sites More sharing options...
BLK'N'YELLOW Posted June 2, 2011 Author Report Share Posted June 2, 2011 (edited) I run 110 octane straight or mixed with pump and about 180 or 185 on the compression did u notice a diff from mixed gas to straight 110 , have u tried c12 from vP , ? Edited June 2, 2011 by BLK'N'YELLOW Quote Link to comment Share on other sites More sharing options...
