laydown Posted May 26, 2011 Report Share Posted May 26, 2011 Okay guys I have a + 8 with American racers 20-10-10 with some +3 front j arms. I weight 140 pounds and I’m at 600cc. Just wondering what will happen if I go to the 1/8 with no bar could I get away with it. I’m going to try it out, just wondering if any of you guys have tried it and what results did you have. Quote Link to comment Share on other sites More sharing options...
SAVAGE420 Posted May 26, 2011 Report Share Posted May 26, 2011 Get a friend to video tape it when you drop the hammer! http://s102.photobucket.com/albums/m88/HillKiller/ATV/?action=view¤t=Bansheebackflip.mp4 Quote Link to comment Share on other sites More sharing options...
nphillybanshee Posted June 26, 2011 Report Share Posted June 26, 2011 (edited) Just drag clutch a bit I have done it. Edited June 26, 2011 by nphillybanshee Quote Link to comment Share on other sites More sharing options...
dajogejr Posted July 7, 2011 Report Share Posted July 7, 2011 It'll work...but there's no way you'll be consistent. The bar doesn't improve your time. It allows you to run a good time over and over again. Natural instinct is to let off when the front end creeps up too far....with the bar, you drop the hammer, slip the clutch and roll out. Quote Link to comment Share on other sites More sharing options...
10second Banshee Posted July 7, 2011 Report Share Posted July 7, 2011 With the right clutch setup and sit close to the tank. You should be ok. It might want to come up during the run down the track. Just stay close to the tank at all times. Quote Link to comment Share on other sites More sharing options...
dajogejr Posted July 8, 2011 Report Share Posted July 8, 2011 I look at it as a safety issue too... I had a buddy on a worked over Raptor wheelie over backwards because of an air leak that ran away on him. If anything happens (panic, runs away, etc.) it can only go as far as the bar. Quote Link to comment Share on other sites More sharing options...
bladesracing Posted July 8, 2011 Report Share Posted July 8, 2011 Any ideas where i can get a wheelie bar?? Quote Link to comment Share on other sites More sharing options...
laydown Posted July 12, 2011 Author Report Share Posted July 12, 2011 Any ideas where i can get a wheelie bar?? So i went to the track, over geared for the quarter and i was running in the 8th no wheelie bar. i would launch and i would get on the other lane and back to the other side close to the wall so basically i was all over the place up on 2. and i ran a 6.3 at 114 with a 1.9 60 foot . I’m hoping that when i put on a wheelie bar i could go straight I’m putting bigger slicks I’m going to go up from a 37 to 40 in the rear to get a better 60 foot and hopefully hit a 5.9 remember I’m a stock frame with plus 3 front j arms . Quote Link to comment Share on other sites More sharing options...
Hilarious Posted July 12, 2011 Report Share Posted July 12, 2011 Any ideas where i can get a wheelie bar?? Stellar here makes one hell of a nice wheelie bar. So i went to the track, over geared for the quarter and i was running in the 8th no wheelie bar. i would launch and i would get on the other lane and back to the other side close to the wall so basically i was all over the place up on 2. and i ran a 6.3 at 114 with a 1.9 60 foot . I’m hoping that when i put on a wheelie bar i could go straight I’m putting bigger slicks I’m going to go up from a 37 to 40 in the rear to get a better 60 foot and hopefully hit a 5.9 remember I’m a stock frame with plus 3 front j arms . A wheelie bar will help not only with safetly issues but your 60' times as well. Quote Link to comment Share on other sites More sharing options...
MatrixBanshee Posted July 12, 2011 Report Share Posted July 12, 2011 So i went to the track, over geared for the quarter and i was running in the 8th no wheelie bar. i would launch and i would get on the other lane and back to the other side close to the wall so basically i was all over the place up on 2. and i ran a 6.3 at 114 with a 1.9 60 foot . I’m hoping that when i put on a wheelie bar i could go straight I’m putting bigger slicks I’m going to go up from a 37 to 40 in the rear to get a better 60 foot and hopefully hit a 5.9 remember I’m a stock frame with plus 3 front j arms . PAPI WOULD BE ASHAMED OF YOU GIVING OUT NUMBERS LIKE THAT Quote Link to comment Share on other sites More sharing options...
laydown Posted July 12, 2011 Author Report Share Posted July 12, 2011 a wheelie bar isn't going straight. it helps keep front end down. if you are launching and going all over the place, you should check to make sure your swingarm and carrier are tight and you have the same air pressure in both tires. maybe i'm going from side to side because my front wheels are in the air and i have no control of the bike . trust me a wheelie bar make a huge differences when you could keep it down on the ground and hit it as hard as you want . Quote Link to comment Share on other sites More sharing options...
