jimbo1986 Posted May 26, 2011 Report Share Posted May 26, 2011 need some help i just put my shee back together from ground up but i forget how all those lines run. i mean the lines that come from the resavoior tank and that T thing and the little line from the water pump. please help Quote Link to comment Share on other sites More sharing options...
spurdy Posted May 26, 2011 Report Share Posted May 26, 2011 need some help i just put my shee back together from ground up but i forget how all those lines run. i mean the lines that come from the resavoior tank and that T thing and the little line from the water pump. please help I haven't run a res tank for years. The one under the water pump is just a vent and can be routed to T into the line connected with the vent on the rear of the transmission upper case have or plugged. Only the line under the water pump can be plugged (the new direct drive covers don't even have this vent), the vent on the rear of the tranny needs to be vented to atmosphere. SP Quote Link to comment Share on other sites More sharing options...
wfobasheeboy Posted May 26, 2011 Report Share Posted May 26, 2011 need some help i just put my shee back together from ground up but i forget how all those lines run. i mean the lines that come from the resavoior tank and that T thing and the little line from the water pump. please help I just plug off the vent line under the water pump. I ran the rear trans vent line up the center of the cards & under the tank up to the top of the steering stem. As for the coolant recovery tank. I ran the line from the rad cap down under the tank then down the right side of the sub frame to the coolant recovery tank & the over flow line runs right back up to the steering stem next to the trans vent line. Hope this help you out. WFO Quote Link to comment Share on other sites More sharing options...
jimbo1986 Posted May 27, 2011 Author Report Share Posted May 27, 2011 I just plug off the vent line under the water pump. I ran the rear trans vent line up the center of the cards & under the tank up to the top of the steering stem. As for the coolant recovery tank. I ran the line from the rad cap down under the tank then down the right side of the sub frame to the coolant recovery tank & the over flow line runs right back up to the steering stem next to the trans vent line. Hope this help you out. WFO it did help thanks and how do u not run the res tank? Quote Link to comment Share on other sites More sharing options...
wfobasheeboy Posted May 27, 2011 Report Share Posted May 27, 2011 it did help thanks and how do u not run the res tank? If you do not want to run the coolant over flow tank. Just run a 4" line straight down off of the rad cap. Quote Link to comment Share on other sites More sharing options...
Jereme6655 Posted May 27, 2011 Report Share Posted May 27, 2011 alot of people have discovered that the stock location is a little strange for the bottle to actually work......i believe its too high. Which allows the tank to not function.......so alot of people will either move it to between the frame rails just behind the bumper....or remove it completely.... it will run with no resivour..... Quote Link to comment Share on other sites More sharing options...
Pat the one the only Posted May 27, 2011 Report Share Posted May 27, 2011 thanks guys, cause i did a frame up rebuild on my banshee and when i put the engine in i couldnt for the life of my figure out where the coolant overflow line went lol, i didnt know if it went some place special or not, lol. honestly how effective is the stock banshee coolant overflow tank and how much does it help, because i go on all day trail rides riding in places where the shee could easily overheat, should i run it or forget about it? Quote Link to comment Share on other sites More sharing options...
Coupelx Posted May 27, 2011 Report Share Posted May 27, 2011 alot of people have discovered that the stock location is a little strange for the bottle to actually work......i believe its too high. Which allows the tank to not function.......so alot of people will either move it to between the frame rails just behind the bumper....or remove it completely.... it will run with no resivour..... too high or too far back there? mine would never draw coolant back into the radiator like its supposed to as it cools. ended up ditching it and calling it a day. Quote Link to comment Share on other sites More sharing options...
