Anyone had a problem with Mod quad drag axle sprocket hub and wheel hub fused together with the axle? I was going to change my gearing, Dam hubs were really stuck to the axle. So after a few hammer blows with a rubber mallet it gave way, sanded it smooth and reassembled it. Maybe there was something I was supposed to put in between the hub and axle?
Mine we all stuck after last season as well.... I am hoping after the nice polish job from Mr. Bling I will not have this problem anymore...
Overall I have really like the quality and function of the modquad axle.
-JD
my jj+a slips apart very nnicely every time.
you should try antisieze very very very thin on it. or plain ole axle grease.. every surface where 2 metals meet should have a small amount of lube to conteract moisture and siezing.
like the swingarm bolt.. and stock axles, front hub's etc.
ive got a that same axle and it seems like after every ride the stupid thing comes loose,ive tried lock tight and brass washers and still after ever ride loose. banghead ..... over time ive come to just deal with it,now my other jj&a never a problem.
