Pat the one the only Posted May 15, 2011 Report Share Posted May 15, 2011 Hi guys, i put my engine back together and i bought a case saver just for extra protection lol and i thought all banshee case savers accepted up to a 15 tooth front sprocket, but the modquad one doesnt, which i really dont like cause i wanted to run 15-41 gearing now my question is will a stock size 14 tooth work? is there another brand of case saver that would work with a 15 front? im not sure which route i wanna go yet Quote Link to comment Share on other sites More sharing options...
Banshee Chad Posted May 15, 2011 Report Share Posted May 15, 2011 Get a T.M. Design works one. Looks to be the most protective. Easy install, and I feel good itle work if needed. Quote Link to comment Share on other sites More sharing options...
spurdy Posted May 15, 2011 Report Share Posted May 15, 2011 Get a T.M. Design works one. Looks to be the most protective. Easy install, and I feel good itle work if needed. TM Design wont allow the fit of a 15t sprocket either. A little modifying and it will fit but not out of the package. SP Quote Link to comment Share on other sites More sharing options...
Banshee Chad Posted May 15, 2011 Report Share Posted May 15, 2011 TM Design wont allow the fit of a 15t sprocket either. A little modifying and it will fit but not out of the package. SP 15 will fit Quote Link to comment Share on other sites More sharing options...
bigblockbanshee Posted May 15, 2011 Report Share Posted May 15, 2011 (edited) 15 will fit Can you show us how? Kinda curious because mine will barely accept a 14... OP sounds like you just need to get out the die grinder and make your own extra clearance for it, just my 2 cents. Edited May 15, 2011 by bigblockbanshee Quote Link to comment Share on other sites More sharing options...
SAVAGE420 Posted May 16, 2011 Report Share Posted May 16, 2011 Will take you 2 mins to shave it down with a dremel or even by hand. Tighter the fit the better. I shaved mine down to run larger sprockets. Quote Link to comment Share on other sites More sharing options...
