low end bog
the end of last season i put in a k&n filter and ever since i have a low end bog i went from 270 or 280 mains to 310's since i have dropped down to 300's, plugs look perfect but i cant figure out this bog. i have the needles on the middle clip also any help would be appreciated
You need to adjust your pilots and or air screws.
Needles have most affect between 1/2 to 3/4 throttle. Mains have most affect between 3/4 to WFO.
mine will sit and idle all day, but still has low and bog. should i still plan on adjusting the needle?
Does it get better when you go clockwise or counter clockwise on the air screws?
Clockwise is richer, counter clockwise is leaner.
basically if i tighten it all the way i would only be a half turn out right now and there is no bog
