fleury_xlt Posted May 4, 2011 Report Share Posted May 4, 2011 Hi! I've got my brand new +4 swingarm on my Shee. I'm 230 pounds and 6'2. The stock suspension is too soft for me. which one do you guys use ? I want something affordable please ! Thanks Quote Link to comment Share on other sites More sharing options...
06specialedition Posted May 4, 2011 Report Share Posted May 4, 2011 The most affordable thing would be getting your stock rear shock set up for your longer swingarm and weight. Hit up Matt with So Cal Suspension Systems.....only guy to go through for suspension stuff IMO. http://www.socalsuspensionsystems.com/ His name on here is MattSCESC Quote Link to comment Share on other sites More sharing options...
fleury_xlt Posted May 4, 2011 Author Report Share Posted May 4, 2011 The most affordable thing would be getting your stock rear shock set up for your longer swingarm and weight. Hit up Matt with So Cal Suspension Systems.....only guy to go through for suspension stuff IMO. http://www.socalsuspensionsystems.com/ His name on here is MattSCESC There are no shock like YFZ 450 or Raptor that will fit and will be stiffer ? Quote Link to comment Share on other sites More sharing options...
So Cal Suspension Posted May 5, 2011 Report Share Posted May 5, 2011 There are no shock like YFZ 450 or Raptor that will fit and will be stiffer ? YFZ shocks will not fit, as they are about 4" too long, and use a different style lower mount. Raptor shocks are the exact same spring rate as a stock banshee rear. 5.4kg/mm. The cheapest option would be to get a heavier Eibach spring, and not mess with the valving of the shock at all. I stock them, and they are $109.00ea. You can either install it yourself, or I can do the installation for an addition $25, including return shipping. Quote Link to comment Share on other sites More sharing options...
fleury_xlt Posted May 5, 2011 Author Report Share Posted May 5, 2011 YFZ shocks will not fit, as they are about 4" too long, and use a different style lower mount. Raptor shocks are the exact same spring rate as a stock banshee rear. 5.4kg/mm. The cheapest option would be to get a heavier Eibach spring, and not mess with the valving of the shock at all. I stock them, and they are $109.00ea. You can either install it yourself, or I can do the installation for an addition $25, including return shipping. Thanks for your help ! I'll check at that !! Quote Link to comment Share on other sites More sharing options...
STINKYDELUXE Posted May 6, 2011 Report Share Posted May 6, 2011 If you dont need the travel I ran a +8 swing arm with the shock direct to the swing arm (no Link) a moved the top shock mount. I tested it first before mounting it by putting a 2x4 under the frame rails and rested the shock under it. I weight 225# it didnt cost anything and worked good. Quote Link to comment Share on other sites More sharing options...
fleury_xlt Posted May 6, 2011 Author Report Share Posted May 6, 2011 If you dont need the travel I ran a +8 swing arm with the shock direct to the swing arm (no Link) a moved the top shock mount. I tested it first before mounting it by putting a 2x4 under the frame rails and rested the shock under it. I weight 225# it didnt cost anything and worked good. Thanks for the idea ! Quote Link to comment Share on other sites More sharing options...
sleeper06 Posted May 7, 2011 Report Share Posted May 7, 2011 I have a r6 shock out of a street bike ohlins shock pretty cool and i got it for a steal on flea bay Quote Link to comment Share on other sites More sharing options...
STINKYDELUXE Posted May 7, 2011 Report Share Posted May 7, 2011 I'll see if I can post up some pics this weekend. Quote Link to comment Share on other sites More sharing options...
