F/S: 18cc domes and Cascade exhaust clamps
Green, are you running a short rod or long rod stroker? Does it have a spacer plate?
You can't run a non-stroker dome if you have a long rod crankshaft.
NO spacer plate
stocke jugs bored out
the pistons i order part number says its a 4 mm piston but the pistons only go flush with the jug. the top doesnt go into the head.
and the cir clip hole / rod hole or whatever u call it.. the hole in the piston is off set up toward the topp of the piston than a stock hole piston is .
  • 1 month later...
