Banshee carb
ECshee
Side by side the stock 26mm mikuni carb for a banshee and blaster are primarily the same. My question is, if i put a vaccuum cap on the choke tube side, could i use this on my blaster? It already has the idle screw and cap for the TORS delete installed, unlike my blaster. So to save myself a few bucks i figured id give it a shot, in theory i guess it makes sense and would work....in my head. I could be wrong. Let me know! :cheers:
I did use the left-side carb, if you were sitting on the bike. The fuel line will connect, the vent tubes have been re-tubed, and the choke tube has been vacuum capped off. If it works the way i want it to, it would save me roughly $40 for the TORS delete kit, and instead i can buy new clutch and throttle cables. I dont know if the choke tube being capped off would create any negative space in the carb that could cause it to drag/ lag. Sounding and looking like i might try it though... :cheers:
