Pat the one the only Posted April 28, 2011 Report Share Posted April 28, 2011 Hi, i did a complete rebuild on my engine including switching the tranny into a set of 2001 cases from a BHQ member, and after i had it assembled i noticed the shift fork rods are open out by the sprocket, but the old 1993 cases had metal plugs in these holes, how do i get them out and put them in the new cases, any help would really be apreciated, thanks guys. Quote Link to comment Share on other sites More sharing options...
georgie Posted April 28, 2011 Report Share Posted April 28, 2011 Hi, i did a complete rebuild on my engine including switching the tranny into a set of 2001 cases from a BHQ member, and after i had it assembled i noticed the shift fork rods are open out by the sprocket, but the old 1993 cases had metal plugs in these holes, how do i get them out and put them in the new cases, any help would really be apreciated, thanks guys. put the shift fork rods back in, find a rod with the same diameter and hammer it out from the clutch side. I came across 1 case that had jb weld around those pugs. I guess the previous owner had problems with it coming loose. Quote Link to comment Share on other sites More sharing options...
Larry's Shee Posted April 28, 2011 Report Share Posted April 28, 2011 I do believe those are designed for one time installation. I would try a Yammy dealer or site sponser, or good auto parts might be able to hook you up. Worst case if you re-use put some Yamma bond or 3-bond on before install. Quote Link to comment Share on other sites More sharing options...
bansheesandrider Posted April 28, 2011 Report Share Posted April 28, 2011 Yes, they are a one time use so you will need to get new ones from Yamaha. They are shown on the same parts diagram as the shift forks and the part number is 90334-10006-00. I have never seen any at the auto parts store that were small enough. If you reuse them and they come out while riding, you will lose your tranny oil and have to haul it back becuase with no oil in the tranny you don't want to tow it and have all the bearings and gears turning without oil. Not worth reusing to save $7. Quote Link to comment Share on other sites More sharing options...
Pat the one the only Posted April 28, 2011 Author Report Share Posted April 28, 2011 can you install them with the cases together? Quote Link to comment Share on other sites More sharing options...
bansheesandrider Posted April 29, 2011 Report Share Posted April 29, 2011 can you install them with the cases together? YES Quote Link to comment Share on other sites More sharing options...
BigRed350x Posted April 29, 2011 Report Share Posted April 29, 2011 You can get the little aluminum plugs from cascade innovations. You can put them in with the cases together no problem. Just make sure you have them flat and flush before you pound them into the case. You don't want them to go in crooked or it can wallow out the hole and they will never seal. Quote Link to comment Share on other sites More sharing options...
Big Bucks Posted April 30, 2011 Report Share Posted April 30, 2011 ive put these in before, real easy. i put a lil red lock tite on them and tapped them in , never have had a problem Quote Link to comment Share on other sites More sharing options...
