can this be repaired?
I've run them in a lot worse shape than that. Those don't look that bad. I would just get some sand-paper and clean up the inside of the cylinder wall and get a machinists flat-edge and check the deck of the cases. If the deck isn't flat I would get a refund since its a sealing surface. If the deck is good, run em!
