03banshee20 Posted April 23, 2011 Report Share Posted April 23, 2011 hey i need quick help. i broke a throttle cable on my banshee and it ran great before this. so i have 290 mains. air screw is out 1.5 turns fmf ssts. vf3. +4 timing. i got a new throttle cable and put it together and its way too rich. what happened? Quote Link to comment Share on other sites More sharing options...
Screamin_Banshee Posted April 23, 2011 Report Share Posted April 23, 2011 Stock carbs? Choke tube in place? Slide's in correctly? Cable adjusted properly? Quote Link to comment Share on other sites More sharing options...
sleeper06 Posted April 24, 2011 Report Share Posted April 24, 2011 as stated if slides are out of adjustment from new cable,could be problem,or outta sync Quote Link to comment Share on other sites More sharing options...
03banshee20 Posted April 24, 2011 Author Report Share Posted April 24, 2011 Stock carbs? Choke tube in place? Slide's in correctly? Cable adjusted properly? everythings in perfect idk what would cause this. and stock carbs Quote Link to comment Share on other sites More sharing options...
Screamin_Banshee Posted April 24, 2011 Report Share Posted April 24, 2011 Hmm. you shouldnt have changed the airflow of the motor with just a cable. Is it lifting the slides all the way? Needles sitting all the way down in the slides? If it was me, I'd pop the carbs off and give a good cleaning. Quote Link to comment Share on other sites More sharing options...
06specialedition Posted April 24, 2011 Report Share Posted April 24, 2011 everythings in perfect idk what would cause this. and stock carbs A new cable would not make it run rich. Is there anything else you did while it was apart? Quote Link to comment Share on other sites More sharing options...
volcrano Posted April 24, 2011 Report Share Posted April 24, 2011 hey i need quick help. i broke a throttle cable on my banshee and it ran great before this. so i have 290 mains. air screw is out 1.5 turns fmf ssts. vf3. +4 timing. i got a new throttle cable and put it together and its way too rich. what happened? i guarantee u put the slides in backwards.the cutaway on the slide faces the back of the carb,so taking ur air filter off and looking thru at the slides,u should see a little quarter moon cutout at the bottom.if u dont see that,u put the slides backwards in the wrong carburetors.switch them. Quote Link to comment Share on other sites More sharing options...
03banshee20 Posted April 25, 2011 Author Report Share Posted April 25, 2011 Hmm. you shouldnt have changed the airflow of the motor with just a cable. Is it lifting the slides all the way? Needles sitting all the way down in the slides? If it was me, I'd pop the carbs off and give a good cleaning. did that didnt help anything Quote Link to comment Share on other sites More sharing options...
03banshee20 Posted April 25, 2011 Author Report Share Posted April 25, 2011 i guarantee u put the slides in backwards.the cutaway on the slide faces the back of the carb,so taking ur air filter off and looking thru at the slides,u should see a little quarter moon cutout at the bottom.if u dont see that,u put the slides backwards in the wrong carburetors.switch them. i dint think you can put the slides in backwards Quote Link to comment Share on other sites More sharing options...
volcrano Posted April 25, 2011 Report Share Posted April 25, 2011 i dint think you can put the slides in backwards yes u can.did u check that there is the slide cutout towards the back?just switch them anyway,thats what happened.a bike will never run rich by changing a cable.slides are in the wrong carb. Quote Link to comment Share on other sites More sharing options...
03banshee20 Posted April 25, 2011 Author Report Share Posted April 25, 2011 yes u can.did u check that there is the slide cutout towards the back?just switch them anyway,thats what happened.a bike will never run rich by changing a cable.slides are in the wrong carb. would this make it so when i pll the choke it makes no difference?? Quote Link to comment Share on other sites More sharing options...
Screamin_Banshee Posted April 25, 2011 Report Share Posted April 25, 2011 Your slides...have you checked them? Im almost positive theyre not correctly installed. Quote Link to comment Share on other sites More sharing options...
