need step by step info and pics on installing yfz a arms on a banshee
CAUSE THE SHIT DONT FIT!
wtf!?....watt part of it doesntt fit?!
because it was meant to be decent geometry for a yfz. not a banshee. They will fit.....but they weren't designed for it....so they WILL tear other things....just call or talk to matt.....he's our suspension sponsor on here. you can easily change things around with his help AND it will be the a setup that is good for a banshee....
I know a lot of the guys are downing this, But I'm running a yfz front end and it's a shit ton better then my shee was with stock shit on it. I used the complete front end including spindles and 2009 450r shocks. I think a lot of guys are having problems because of using the shee spindles instead of the yfz spindles. All in all this setup cost me 300 including the shocks that had no ride time at all, if you compare that to over a grand for a +2+1 front end and shocks it's a no brainer. So in my opinion if you just ride for recreation it's a good setup well its better then the shees stock shit thats for sure. And by the way the yfz calipers will work fine with the shees rezzi, I've been running mine like that for a year now with no issues. Just my .02
http://www.blasterforum.com/suspension-14/guide-fitting-yfz-450-complete-front-suspension-blaster-36120/ Only way I can think of explaining how to keep the relationship of the arms . IMO, keeping the X Y Z dimentions correct is the proper way to make this work. I have read every thread dealing with J-arms , and almost all for YFZ arms/shocks and there are a good percentage that end up ditching the YFZ parts. :shrugani:
JMHO, your results may, and will vary. :cheers::jesterlaugh:
wat do you mean it doesnt fit?
