Elka fitment
Glenyboy
I've seen a set of front and back elkas for sale problem is they are for a blaster, would they go on a stock banshee?
Thanks
P.s. Not sure would type they are there just labelled as elka
The rear will be too long, and the fronts will be a TAD short.
I believe the rear on a blaster is like 15.5"... Not 100% positive, but I think I recall them being longer than a stock banshee rear.
Also, the fronts I think are 13.5"
I did the Banshee shock "upgrade" on my Blaster. You are going the other way so here is what I remember....
The stock Blaster shocks have a stiffer spring rate than the stock Banshee shocks.
The Blaster shocks are more than 1/2" shorter than Banshee shocks.
Blaster shocks had significantly smaller/shorter coils than the Banshee version....as far as stock shocks go.
So, smaller, shorter, stiffer following stocker spec. As far as what parameters Elka changes....IDK.
