nastyracing Posted April 21, 2011 Report Share Posted April 21, 2011 I'm trying to jet my duner. Motor a fresh build. 18cc domes v force 2 reeds. Timing +4 heavy CPI dune/drag port Lrd exhaust air box no lid. Compression 205 psi in each hole yes on race fuel. I ran first day out with 160 50 pilot 1.5 turns on air screw. Bike ran ok down low but 3/4 was faster then full bike wouldn't rev out. So I dropped to 155 main helped bring bike threw all the revs but still very slow. When I tried dropping to 48 pilot at both 1.5 turns out n 2 turns bike wouldn't start when did idle high the revs stuck. So I went back to the 50 now currently at 2 turns on air screw w 50 pilot n the best its been rideable but not right... So my question is after I reach 2.5 turns out on air screw w current 50 pilot then I have to drop to 48? So if I put the 48 back in could I possibly get away n be right w only half of turn on air screw or 1 turn never tried that. But at 1.5 -2 turns bike was to lean n didn't like that pilot. Ne suggestion cause everyone else carbs I pulled apart w similar set ups had 48 pilots actually all of them did. N smaller mains one was lean n mean around 145 so suggestions please. Quote Link to comment Share on other sites More sharing options...
nastyracing Posted April 21, 2011 Author Report Share Posted April 21, 2011 Also my bore is at 65.5 n fresh . Quote Link to comment Share on other sites More sharing options...
sleeper06 Posted April 23, 2011 Report Share Posted April 23, 2011 can you get a chop out of it,seems to me a heavy dune drag port should be more in the 168-175 range on the mainIMO Quote Link to comment Share on other sites More sharing options...
nastyracing Posted April 23, 2011 Author Report Share Posted April 23, 2011 Well got dropped my needle one clip position to richen it up and drop pilot down to 48 two turns on air screw. Main now at 155 gonna run it next trip out and then try 150main if not happy ... Quote Link to comment Share on other sites More sharing options...
nastyracing Posted April 26, 2011 Author Report Share Posted April 26, 2011 I re sync my carbs were they were off.. But have one left exhaust which is very hot and right is cool to the touch not hot at all what sense does this make. Quote Link to comment Share on other sites More sharing options...
Coupelx Posted April 26, 2011 Report Share Posted April 26, 2011 i am at a 142 main with a dune port and r2's on my 28mm pwks and its still a bit rich. 45 pilots. Quote Link to comment Share on other sites More sharing options...
