new engine help
so i just put together my new ported engine and new crank and started up today and the one side got hot and the other side is taking it a bit to warm up , at the tail pipe the it pushing not cool but normal temp air and the other is hot plus the one thats pushing cool air has oil like gas mixture , help is needed is this normal untill engine breaks in or what . oh they both have same compression and took the filters off and carbs are spitting gas also there is spark for both
maybe a airleak???
yea started it up again after making sure everything is tight and no cracks , and the one side heats up quick and after couple min the one side is still cool the jug is heating up a bit but the one pipe is cool and the other is hot
mabey you needa adjust air/fuel mixture. mine did that and i adjusted it and everything got better :) or adjust your idle. that also helped mine out lol.
So I swapped plug wires and put a different plug in and still ran cool and it started to act boggy like loss of power won't rev and I looked around the carbs and saw smoke coming out of the boot between the reed and boot so is that something major or just cause there must of been an air leak it leaked out there instead of the pipe
Yea I took the head off there was a broken oring that ust of got pinched putting it together. So fixed that and fired it up it heated up with the other side not as much and still not nearly as much puffing white out the top of the cylinder after yanking plug after fire but did sound much better but now that side of the bike start reving higher then quits so I'm going to look at the carb even tho its brand new maybe something is up in there also
