Slogoat Posted April 14, 2011 Report Share Posted April 14, 2011 I have a newly built 421cc cub with 35 keihin carbs and t-5 exhaust. My problem is the t-5s don't fit on the exhaust ports that well and the exhaust on the driver's side is almost touching the carb and does touch the fuel line! No way to move the fuel line because it is where the fuel inlet is. I am thinking of going to another set of pipes, but was hoping to use the t-5s. Any thoughts on the t-5s? Any suggestions on the new pipe possibilities and anybody know what will fit? Let me know. Thanks, Matt Quote Link to comment Share on other sites More sharing options...
bigblockbanshee Posted April 14, 2011 Report Share Posted April 14, 2011 I have a newly built 421cc cub with 35 keihin carbs and t-5 exhaust. My problem is the t-5s don't fit on the exhaust ports that well and the exhaust on the driver's side is almost touching the carb and does touch the fuel line! No way to move the fuel line because it is where the fuel inlet is. I am thinking of going to another set of pipes, but was hoping to use the t-5s. Any thoughts on the t-5s? Any suggestions on the new pipe possibilities and anybody know what will fit? Let me know. Thanks, Matt Use some spacers (washers, etc.) to get the fit you need and get everything snug. Get everything lined up how you want and tighten it up from the rear to the front. I had the same issue with my T5s, just takes a little creativity and lots of patience. Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted April 14, 2011 Report Share Posted April 14, 2011 My T5's were really close too. I just turned the carb slightly. Quote Link to comment Share on other sites More sharing options...
J-Madd Posted April 14, 2011 Report Share Posted April 14, 2011 I have a newly built 421cc cub with 35 keihin carbs and t-5 exhaust. My problem is the t-5s don't fit on the exhaust ports that well and the exhaust on the driver's side is almost touching the carb and does touch the fuel line! No way to move the fuel line because it is where the fuel inlet is. I am thinking of going to another set of pipes, but was hoping to use the t-5s. Any thoughts on the t-5s? Any suggestions on the new pipe possibilities and anybody know what will fit? Let me know. Thanks, Matt Not related to your issue, but are you running a dual pingel and modded the gas cap? If not, you need to do that before running it hard. Quote Link to comment Share on other sites More sharing options...
