Banshee makeover, how can I improve it for a decent amount $ ?
most of the parts on my banshee are in rough shape, but the motor and carbs are still in good condition. I stripped absolutely every part off and decided to put it back together properly and take the time to make the necessary mods.
I don't want to just put it back together with stock parts this time, so I was wondering, what kind of mods could I achieve with about 400-500$ that would increase it's power without compromising the life of the engine?
-My equalizer tube is punctured, is it worth it to put a booster bottle instead?
-are v-force reeds worth it? if yes, do i need to re-jet the carbs if i put them in?
- is it fairly simple or even possible to put a tachometer on a banshee?
- Is there any other after market parts that i should consider?
thanks
Don't get a boost bottle, just get a replacement crossover tube. I'm sure someone on here has one they would sell you. If you don't have pipes, they will help a lot but can be expensive. An aftermarket timing plate is great cheap mod too, only costs around 50 bucks.
