bigdogchevy98 Posted April 6, 2011 Report Share Posted April 6, 2011 1/2 gallon. 64 oz. Is this a new oversized radiator or an old stock one? stock radiator, sorry your right, 1/2 gal. stuff works great tho! Quote Link to comment Share on other sites More sharing options...
andrew3160 Posted April 6, 2011 Author Report Share Posted April 6, 2011 1/2 gallon. 64 oz. Is this a new oversized radiator or an old stock one? This is a new one, I was using their piece of a cap and I run engine ice. Hopefully the stock cap will make a difference. Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted April 7, 2011 Report Share Posted April 7, 2011 This is a new one, I was using their piece of a cap and I run engine ice. Hopefully the stock cap will make a difference. How do the tube ends looking down through the radiator cap? Could possibly be a bad weld / solder job and pluged off some tubes. That would drastically decrease the cooling capacity of the radiator. Quote Link to comment Share on other sites More sharing options...
jasons Posted April 7, 2011 Report Share Posted April 7, 2011 correct me if i'm wrong, but if you were burning the coolant in your cylinders, wouldn't that make your spark plugs white? also, fyi, i know "Engine Ice" is a special coolant that supposedly lowers temps on engines up to 50 degrees. I've heard nothing but good things about Engine Ice, and it's only $20 for a gallon that would be 20 dollars for a half gallon not a whole gallon Quote Link to comment Share on other sites More sharing options...
