yamahaman244 Posted May 23, 2011 Report Share Posted May 23, 2011 What I have been doing is taking a quart of oil I use r50 klotz and put in a little back pack or something pull up to the pump shut gas off and put your gas in and make sure u see how. Many gallons u put in Say two put 8 oz in for 32.1 and shake the bike back and forth and go I was worried like they said before about mixing it wrong but after. A few times u get use to it havet had a problem doing it that way Quote Link to comment Share on other sites More sharing options...
scotts96fast Posted May 23, 2011 Report Share Posted May 23, 2011 No I mean like how do I properly mix the oil in the gas at the pump. Put the oil in first then gas or gas in the oil and shake the quad a little....haha that's what im confused about I carry a 2 gallon gas can in my six pack rack.strap a quart of oil on my nerf bar.Add the oil to the gas can and pump gas into can.I try not to carry gas in can because i've had lost the six pack rack in the woods and cracked the frame from the added weight.BUT this is over many years Quote Link to comment Share on other sites More sharing options...
Coupelx Posted May 23, 2011 Report Share Posted May 23, 2011 i used to put enough oil for a couple gallons in a 20oz bottle with a few oz of gas to thin it out. the idea was that it would mix easier. Quote Link to comment Share on other sites More sharing options...
Loc Posted May 24, 2011 Report Share Posted May 24, 2011 Lets say I need 2.5 gallons of gas to top off the tank. I put the oil in first then tart pumping. I stop the pump at 2.5 gallons. My theory is that the pressure of the gas rushing into the tank does all the mixing for me. Never had any problems. Done it like this plenty of time. Quote Link to comment Share on other sites More sharing options...
spurdy Posted May 25, 2011 Report Share Posted May 25, 2011 Lets say I need 2.5 gallons of gas to top off the tank. I put the oil in first then tart pumping. I stop the pump at 2.5 gallons. My theory is that the pressure of the gas rushing into the tank does all the mixing for me. Never had any problems. Done it like this plenty of time. Amen! Do you put your gas can in a paint shaker to mix it after adding your oil ? I can't believe there are that many posts about mixing fuel! The oil is *designed* to mix with the fuel. Piece of cake, just know how much gas you put in and add oil accordingly, Shake bike back and forth and get back to riding. SP Oh, and how the fuck did you get a pic of my bike in your sig, loc? Quote Link to comment Share on other sites More sharing options...
Coupelx Posted May 25, 2011 Report Share Posted May 25, 2011 Amen! Do you put your gas can in a paint shaker to mix it after adding your oil ? I can't believe there are that many posts about mixing fuel! The oil is *designed* to mix with the fuel. Piece of cake, just know how much gas you put in and add oil accordingly, Shake bike back and forth and get back to riding. SP Oh, and how the fuck did you get a pic of my bike in your sig, loc? its his friends bike. thats wierd how close they are though! Quote Link to comment Share on other sites More sharing options...
