adam uk Posted March 28, 2011 Report Share Posted March 28, 2011 Please help.. Whilst riding recently in really heavy mud my banshee suddenly stopped as if it popped out of gear (i was going up hill) I then tried getting it back in gear, it seemed to be going into each gear but no drive? So thought maybe id killed the clutch as there was a smell like a frazzled clutch.. New clutch ordered an installed.. Starts up first kick as always and goes into each gear but doesnt seem to actually engage anything, just sits and revs? what could be the problem? Any help would be greatly appreciated. Quote Link to comment Share on other sites More sharing options...
adam uk Posted March 28, 2011 Author Report Share Posted March 28, 2011 no one know? Quote Link to comment Share on other sites More sharing options...
n2otoofast4u Posted March 29, 2011 Report Share Posted March 29, 2011 make any noises? Quote Link to comment Share on other sites More sharing options...
Larry's Shee Posted March 29, 2011 Report Share Posted March 29, 2011 (edited) gear on crank tight? nut tight? Edited March 29, 2011 by Larry's Shee Quote Link to comment Share on other sites More sharing options...
adam uk Posted March 29, 2011 Author Report Share Posted March 29, 2011 gear on crank tight? nut tight? whats that, how do i get to it, would i need to split the cases? Quote Link to comment Share on other sites More sharing options...
bansheesandrider Posted March 29, 2011 Report Share Posted March 29, 2011 whats that, how do i get to it, would i need to split the cases? Remove your clutch cover, it is right there on the end of the crank. Also inspect the key in the gear and make sure when you move the shifter, that it turns the shift star/drum. If this all checks out, then you will probably have to split the cases. If you don't know what the things I mentioned are, you need to get a service manual and start reading so you know how your bike works. Also spend some time on this website reading the technical information and some of the threads in the repair section. Quote Link to comment Share on other sites More sharing options...
adam uk Posted March 29, 2011 Author Report Share Posted March 29, 2011 make any noises? no, no noise starts up fine goes in gear fine but no forward momentum ? Quote Link to comment Share on other sites More sharing options...
adam uk Posted March 29, 2011 Author Report Share Posted March 29, 2011 Remove your clutch cover, it is right there on the end of the crank. Also inspect the key in the gear and make sure when you move the shifter, that it turns the shift star/drum. If this all checks out, then you will probably have to split the cases. If you don't know what the things I mentioned are, you need to get a service manual and start reading so you know how your bike works. Also spend some time on this website reading the technical information and some of the threads in the repair section. looks like its time to open it back up again! lol is either of these a common problem for coming loose? Quote Link to comment Share on other sites More sharing options...
05colorado Posted March 29, 2011 Report Share Posted March 29, 2011 Check the front sprocket nut to se if it is still there. Could have backed out and the sprocket slipped off the splines. Happened to me and ruined the shaft, had to change the output shaft inside the trans. Quote Link to comment Share on other sites More sharing options...
