bansheeman_05 Posted March 26, 2011 Report Share Posted March 26, 2011 I finally got the 87 build fired up the other day. I went out to the garage this afternoon and noticed a small bit of oil under her on the sprocket side. I looked and it seems to be coming out of the hole just below the front sprocket in the case. I tried to do a search to see if there should be machined plug in it and it looks like there should be. Yamaha OEM parts finder does not show me anything. Does anyone know if there should be something there? And if there should be does anyone have a jump case they could punch one out for me? Thanks! Quote Link to comment Share on other sites More sharing options...
volcrano Posted March 26, 2011 Report Share Posted March 26, 2011 there shouldnt be a hole.the only thing under the front sprocket is the neutral switch and to the right of that the shifter shaft which also has a seal. Quote Link to comment Share on other sites More sharing options...
Larry's Shee Posted March 26, 2011 Report Share Posted March 26, 2011 If you're talking hole for shift rail, the plug is one time use. Get a new one, clean area, use yamma bond or three bond. JMHO, your results may vary. Quote Link to comment Share on other sites More sharing options...
88banshee Posted March 26, 2011 Report Share Posted March 26, 2011 (edited) I finally got the 87 build fired up the other day. I went out to the garage this afternoon and noticed a small bit of oil under her on the sprocket side. I looked and it seems to be coming out of the hole just below the front sprocket in the case. I tried to do a search to see if there should be machined plug in it and it looks like there should be. Yamaha OEM parts finder does not show me anything. Does anyone know if there should be something there? And if there should be does anyone have a jump case they could punch one out for me? Thanks! my 1979 yz80 finaly had somethin wrong with it and its exactly as yours but no plug a lil hole from a rock or sumthin it was drainin a lot of oil and i used black silicone to fix it it worked for a lil while then i used jb weld havent had a probalem for a yr Edited March 26, 2011 by 88banshee Quote Link to comment Share on other sites More sharing options...
bansheesandrider Posted March 26, 2011 Report Share Posted March 26, 2011 I finally got the 87 build fired up the other day. I went out to the garage this afternoon and noticed a small bit of oil under her on the sprocket side. I looked and it seems to be coming out of the hole just below the front sprocket in the case. I tried to do a search to see if there should be machined plug in it and it looks like there should be. Yamaha OEM parts finder does not show me anything. Does anyone know if there should be something there? And if there should be does anyone have a jump case they could punch one out for me? Thanks! They show the plugs on the page that shows the shift drum and forks. It is part number 90334-10006-00 if you are not able to look it up yourself. And as was mentioned, they are made for 1 install and when remove they are junk, also use some Yamabond 4 when you install them to seal it up. Quote Link to comment Share on other sites More sharing options...
bansheeman_05 Posted March 28, 2011 Author Report Share Posted March 28, 2011 Good deal. Thank you for the help on that. I figured that was the deal on it, but I thought the part would be on the crankcase page. I will get one ordered up. Thanks again for all the help guys! Quote Link to comment Share on other sites More sharing options...
