steering stem bearing
For the nut that holds the lower steering stem bearing in, get a 3/4" bolt about 2" long, which will have a 1 1/8" head. You are essentially using it as a big allen wrench. You can turn the bolt with a pipe wrench or weld a junk socket to the threaded end of the bolt. You can get a new bearing and both seals for $15 shipped off ebay.
There is a seal on top and one on the bottom. Pry them out with a screwdriver.
Oh, and grind off all the unused brackets before you have it coated. ESPECIALLY those 2 rubber bumper brackets on the lower frame tubes for the stock pipes.
Here's a list of some of the others you may or may not want to cut off.
air box brackets
TORS box brackets
foot basket brackets
lower rear fender mount brackets
Then weld in a gusset to reinforce the steering stop.
Edited by Starwriter
