gstaten24 Posted March 12, 2011 Report Share Posted March 12, 2011 (edited) hey everybody, sorry to make another jetting thread but im stumped haha so i have an 02 banshee with stock carbs, cpi pipes, pods v force reeds, cool head, hjr dune ported cylinders with a 4 mil crank i have the timing set at +4. im currently at 4500 ft. right now i have air/fuel at 2 turns out, 320 mains, 35 pilots, and needle clip on the third down. whats happening is it is really hard to start cold but then when it gets warm it starts fine. also when its warm but not hot it runs almost perfect but once it gets completely hot it cuts out on both cylinders in mid range. any help will be greatly appreciated!! Edited March 12, 2011 by gstaten24 Quote Link to comment Share on other sites More sharing options...
gstaten24 Posted March 18, 2011 Author Report Share Posted March 18, 2011 nobody has any ideas? Quote Link to comment Share on other sites More sharing options...
Surfrjag Posted March 19, 2011 Report Share Posted March 19, 2011 sounds like its running lean... have you tried adjusting the air screw while its warmed up? i would move the clip up 2 positions and mess with air screw and see if it clears up. Quote Link to comment Share on other sites More sharing options...
gstaten24 Posted March 19, 2011 Author Report Share Posted March 19, 2011 ok great thanks ill try that Quote Link to comment Share on other sites More sharing options...
pr0blumz Posted March 20, 2011 Report Share Posted March 20, 2011 Ask Kevin @HJR what your jetting should be. His user name on here is KEVSWS6. He had me almost spot-on when I was running the very same setup. Quote Link to comment Share on other sites More sharing options...
gstaten24 Posted March 20, 2011 Author Report Share Posted March 20, 2011 Yea he told me what he thought when he gave me all the parts for my rebuild. Im taking it out today so we will see what happens Quote Link to comment Share on other sites More sharing options...
MILO Posted March 20, 2011 Report Share Posted March 20, 2011 The cold starting issue could be completely seperate from the mid range bog. Make sure the carb bowl with the 'starter jet' is in the left side carb and that the choke tube/crossover tube is on between the carbs. Jetting always starts with the mains. If you've done a plug chop and have the mains dialed, great. If not do that first then move on to the needle & pilot circuits. If the midrange still has a bog raise the clip a notch at a time to see if it smooths out. If you still have issues, the pilot and air screws may need adjusted. Quote Link to comment Share on other sites More sharing options...
gstaten24 Posted March 20, 2011 Author Report Share Posted March 20, 2011 I know the float bowls are correct because it started first kick before I tore it down and rebuilt it. And yes t does have the crossover tube there between the carbs. I wish I had a dyno around here that would make it mug easier but I'm taking it out today and we will see how it goes I'll let you guys know when I get back home Quote Link to comment Share on other sites More sharing options...
gstaten24 Posted March 25, 2011 Author Report Share Posted March 25, 2011 Ok so I finally was able to do some tuning. I went from a 320 main to a 330 main. I moved the needle clip from 2nd slot down from the top to third down. And I played with the air/fuel screw while it was hot. Nothing happened it ran the same as it did before. So then I changed to a 310 main and nothing happened it stayed the same. Then I put the 330 main back in and changed the needle clip from 3rd down to 4th down and still nothing. I played with the air/fuel screw going as far as 3.5 turns out and still didn't change anything. What it's doing is cutting out at about mid range no matter where I have the throttle at. It does it from 1/4 throttle to WOT. any ideas? Quote Link to comment Share on other sites More sharing options...
pr0blumz Posted March 25, 2011 Report Share Posted March 25, 2011 Tried new plugs and tested your coil? Quote Link to comment Share on other sites More sharing options...
gstaten24 Posted March 25, 2011 Author Report Share Posted March 25, 2011 I tested my coil bout a month ago and it was in specs but I'll test it again. And yes it does have fresh plugs in there. I have a spare stator as well I might put that in there just to eliminAte that as the problem Quote Link to comment Share on other sites More sharing options...
midlifecrisis Posted March 26, 2011 Report Share Posted March 26, 2011 Im not from a high elevation, but I do have my bike dialed in pretty good. My mods are comprable to yours minus the 4mil but my jetting numbers are much lower. Now that I have PJs the setup will have to be refined again My setup was 270 mains, and 27.5 pilot, as instructed to me from Wildcard. Youd have to compenstae for the air being thinner, but Im thinking 300 mains and 30 pilots? I ran mine in -25c on 320 mains, and 32.5 pilots and fouled all day long. Quote Link to comment Share on other sites More sharing options...
gstaten24 Posted March 26, 2011 Author Report Share Posted March 26, 2011 Well I ran 300 mains before I switched my t6s for CPI'S and added a dune Port and 4 mill. Kevin at HJR told me to run 330s and they seem ok but no matter how I change my jetting I still have the same problem it doesn't get better and it doesn't get worse so I'm thinking it's an issue with spark Quote Link to comment Share on other sites More sharing options...
gstaten24 Posted April 1, 2011 Author Report Share Posted April 1, 2011 ok i finally figured out what my problem was, for whatever reason the float bowl was getting sucked dry and it was cutting out like it had an electrical issue, so now im just gonna get some 35 mm kehinhs cuz i wanted new carbs anyway. thanks for all the help everyone. Quote Link to comment Share on other sites More sharing options...
