bigborebanshee Posted March 11, 2011 Report Share Posted March 11, 2011 Is anyone using The VP MRX01,U4.4 or VP 100 street blaze. Did you notice a difference over the standard 110 sunoco or Cam 2 pump gas. I know the VP fuels are oxygenated to create more power.The 4stroke riders swear by MRX01 and I noticed it makes the throttle response much better. Has anyone dynoed these fuels on a built banshee? Quote Link to comment Share on other sites More sharing options...
252wheelieking Posted March 11, 2011 Report Share Posted March 11, 2011 Is anyone using The VP MRX01,U4.4 or VP 100 street blaze. Did you notice a difference over the standard 110 sunoco or Cam 2 pump gas. I know the VP fuels are oxygenated to create more power.The 4stroke riders swear by MRX01 and I noticed it makes the throttle response much better. Has anyone dynoed these fuels on a built banshee? I used the U4.4 on my old stock motor & yes it make a big difference from using pump 93 but I dont know compare to 110 or cam 2. Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted March 12, 2011 Report Share Posted March 12, 2011 With a heavly oxygenated fuel you need to drain the carbs and tank after your done riding. #1. It will cause the carbs to corode due to the high oxygen content. #2. If you let it sit in the tank you will loose the oxygen. It is like leaving a soda open. Your fuel will be flat. Quote Link to comment Share on other sites More sharing options...
CGR fmxer Posted March 12, 2011 Report Share Posted March 12, 2011 With a heavly oxygenated fuel you need to drain the carbs and tank after your done riding. #1. It will cause the carbs to corode due to the high oxygen content. #2. If you let it sit in the tank you will loose the oxygen. It is like leaving a soda open. Your fuel will be flat. completety right. i use it all the time. make sure you keep up on maitanence. Quote Link to comment Share on other sites More sharing options...
CFH87 Posted March 12, 2011 Report Share Posted March 12, 2011 Does turbo blue or tocco do that to the carbs also? I plan on running it soon for my build. Quote Link to comment Share on other sites More sharing options...
CGR fmxer Posted March 12, 2011 Report Share Posted March 12, 2011 Does turbo blue or tocco do that to the carbs also? I plan on running it soon for my build. NO, IT DOESNT, BUT ID STILL DO THE MAITINANCE ANYWAY TO BE SAFE Quote Link to comment Share on other sites More sharing options...
CFH87 Posted March 12, 2011 Report Share Posted March 12, 2011 ALLRIGHT THANKS FOR THE HELP lol Quote Link to comment Share on other sites More sharing options...
CFH87 Posted March 12, 2011 Report Share Posted March 12, 2011 I'm sure turbo blue will suffice for what I'm doing. Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted March 13, 2011 Report Share Posted March 13, 2011 Yep Turbo Blue is good stuff. It is made by Sunoco which is a quality fuel company. VP = Very Pricey Quote Link to comment Share on other sites More sharing options...
