HELP!
noob
so im goin to the dunes real soon and after gettiin my bikes ready i noticed water coming fron the vent on the right side. i checked the dip stick and the whole trans is full of water. what could be causing this? i filled the radiator and it is slowly leaking out of the drain plug. any help would be appreciated as i am short on time thank you by the way i have 160 pis in each cylinder
Sounds like your waterpump seal or worst case small pinhole leak in your clutch case.
In sure the pros will chime in though.
Good luck
awesome i had a buddy saying ceacked head/jug i knew yall yould come through. now how do i replace it thanks
Check the oring on the neck that comes throught the case before you do the pump seal, make sure it isnt ripped
o ring good pump seal bad thanks guys yall are awesome couldnt be a better bunch of guys. while im at it maybe someone could tell me why it takes 100 kicks to start when cold
Make sure the water pump shaft isn't grooved as well. A good seal will still leak if the shaft is grooved. Some of the cheap billet pumps have shafts that groove really easy.
SP
