figaro Posted September 4, 2011 Report Share Posted September 4, 2011 great work cant wait to see the rest of the build. Quote Link to comment Share on other sites More sharing options...
Cleanstrokinshee Posted November 2, 2011 Report Share Posted November 2, 2011 Awesome!! Thank you!!! Quote Link to comment Share on other sites More sharing options...
blast off Posted November 10, 2011 Report Share Posted November 10, 2011 I have a kickstarter question, i refered to your write up here and pics and mine looks the same. I noticed that with the cover off if i put the kickstart lever on and turn it the gear will pass the idler gear. My question is does the white plastic that is on the shaft hold it back when the cover is on? Also, is there supposed to be any play at all in the idler gear? Quote Link to comment Share on other sites More sharing options...
BigRed350x Posted November 17, 2011 Author Report Share Posted November 17, 2011 I have a kickstarter question, i refered to your write up here and pics and mine looks the same. I noticed that with the cover off if i put the kickstart lever on and turn it the gear will pass the idler gear. My question is does the white plastic that is on the shaft hold it back when the cover is on? Also, is there supposed to be any play at all in the idler gear? Yes, the white collar holds it from moving past the idler gear once the side cover is installed. Your idler gear should sit pretty snug on the shaft. if it does wobble quite a bit, replace it. they are only like $50 or $60. - Jared Quote Link to comment Share on other sites More sharing options...
Drk Rider Posted November 28, 2011 Report Share Posted November 28, 2011 This was a huge help. Thanks big red. Quote Link to comment Share on other sites More sharing options...
BigRed350x Posted December 3, 2011 Author Report Share Posted December 3, 2011 This was a huge help. Thanks big red. No problem Quote Link to comment Share on other sites More sharing options...
HolySheet Posted February 4, 2012 Report Share Posted February 4, 2012 Awesome work. Too bad you didnt strip all the gears off of the drive axles and show the proper alignment of them. I'm in the middle of replacing the Main Axle so this info will be helpful! Quote Link to comment Share on other sites More sharing options...
dave5.0 Posted February 26, 2012 Report Share Posted February 26, 2012 Ya I've heard bad things about RTV also. I've been using Ultra Grey on mine last couple times but now I've got a leak at my case studs under the crank. Think I'll be using something little more fuel resistant when it comes apart. What about lock tight on bolts inside the clutch cover? Ever had any issues with that? I've also gotten to where I take out the Phillips head bolts and replace them with Allen head ones from the hardware store so I don't have to worry about the stripping out. Nice pictures and write up. Way more patience than I have putting one together. I'd be three days doin all you did and taking pictures. Haha Quote Link to comment Share on other sites More sharing options...
BigRed350x Posted March 16, 2012 Author Report Share Posted March 16, 2012 Ya I've heard bad things about RTV also. I've been using Ultra Grey on mine last couple times but now I've got a leak at my case studs under the crank. Think I'll be using something little more fuel resistant when it comes apart. What about lock tight on bolts inside the clutch cover? Ever had any issues with that? I've also gotten to where I take out the Phillips head bolts and replace them with Allen head ones from the hardware store so I don't have to worry about the stripping out. Nice pictures and write up. Way more patience than I have putting one together. I'd be three days doin all you did and taking pictures. Haha I've never had any issues using the loctite, but I also have the correct tools to remove the bolts when they do have loctite on them. I got a killer deal on a bunch of 1211 here last month so I'm using all that stuff up, once its used up I'll go right back to the red silicone. Its worked fine for me for going on 8 years now. I have a buddy with an engine I built 5 years ago still running it no problem. As long as you give it enough time to cure before exposing it to oil or gas it will work fine. - Jared Quote Link to comment Share on other sites More sharing options...
Gman-7m Posted April 17, 2012 Report Share Posted April 17, 2012 Thanks for the pictures and the time you took for this, Awesome!!! Quote Link to comment Share on other sites More sharing options...
JpRedline Posted June 2, 2012 Report Share Posted June 2, 2012 Nice work Big! Clear pictures & description, i will use this walkaround for my next build! Quote Link to comment Share on other sites More sharing options...
koster88 Posted July 6, 2012 Report Share Posted July 6, 2012 Great Tutorial. I'm going to use this / My Clymers to do my first build. Thank you!!! Quote Link to comment Share on other sites More sharing options...
chayote86 Posted September 8, 2012 Report Share Posted September 8, 2012 Thanks Red just put mine back together. Great job! Ro Quote Link to comment Share on other sites More sharing options...
Finch Posted September 8, 2012 Report Share Posted September 8, 2012 easier just to drive to his house and make him do it all smart and helpful guy thats for sure! Quote Link to comment Share on other sites More sharing options...
Zew Posted October 24, 2012 Report Share Posted October 24, 2012 What media did you use to sandblast? I have a basket case motor that i'm going to be building soon and it would look really nice all sandblasted! Quote Link to comment Share on other sites More sharing options...
