loose shifter
the shifter on my banshee has too much play in it where it attaches to the splined shaft going into the transmission.... I tried tightening the bolt, but no luck.....
Is there any fix for this without just replacing the shifter?????
What I did with mine was pull it off, pull the bolt out, and using a chop saw, was remove some material where it "clamps" down so you can squeeze it tighter... I know it doesn't make much sense, but maybe you can figure it out.
