AKRACIN Posted February 26, 2011 Report Share Posted February 26, 2011 This is my first transmission tear down Im looking for any advice on what to look for with the trans being stuck in third gear? Any must have upgrades to keep from a repeat? Any advice is welcome. is there a bullet proof trans I can buy? Thank you in advance. Quote Link to comment Share on other sites More sharing options...
bansheeboy44 Posted February 26, 2011 Report Share Posted February 26, 2011 This is my first transmission tear down Im looking for any advice on what to look for with the trans being stuck in third gear? Any must have upgrades to keep from a repeat? Any advice is welcome. is there a bullet proof trans I can buy? Thank you in advance. Sounds like a bent shift fork maybe??? Quote Link to comment Share on other sites More sharing options...
MN SHEE Posted February 26, 2011 Report Share Posted February 26, 2011 sounds more like the the claw on the shift shaft sliped off the shift star really easy fix dont even hve to split the cases. Get a climers manual it will walk you right through it. Quote Link to comment Share on other sites More sharing options...
slacker1bob Posted February 26, 2011 Report Share Posted February 26, 2011 sounds more like the the claw on the shift shaft sliped off the shift star really easy fix dont even hve to split the cases. Get a climers manual it will walk you right through it. Yeah, check the shaft first. I had a similar thing happen. I thought I had to tear into the trans, and I piulled the clutch cover and the claw just slipped off the star. Easy fix Quote Link to comment Share on other sites More sharing options...
AKRACIN Posted February 26, 2011 Author Report Share Posted February 26, 2011 Yeah, check the shaft first. I had a similar thing happen. I thought I had to tear into the trans, and I piulled the clutch cover and the claw just slipped off the star. Easy fix Boy that would be real cool I will check it tomorrow thanks you guys ROCK. Quote Link to comment Share on other sites More sharing options...
Coupelx Posted February 26, 2011 Report Share Posted February 26, 2011 yea the shift shaft just kinda chills there in the cases. the clutch cover is supposed to keep it in place i think. Quote Link to comment Share on other sites More sharing options...
spurdy Posted February 26, 2011 Report Share Posted February 26, 2011 Boy that would be real cool I will check it tomorrow thanks you guys ROCK. If that is what the problem is you might want to replace the shift shaft. The rivet that holds the claw on wears and develops too much play in it and it will do the same thing again. The claw should rotate freely but not have excessive wobble to it. SP Quote Link to comment Share on other sites More sharing options...
AKRACIN Posted February 28, 2011 Author Report Share Posted February 28, 2011 If that is what the problem is you might want to replace the shift shaft. The rivet that holds the claw on wears and develops too much play in it and it will do the same thing again. The claw should rotate freely but not have excessive wobble to it. SP You guys were correct. Pulled the clutch cover and touched the shift shaft and walla all my gears are back. Thanks so very much. Quote Link to comment Share on other sites More sharing options...
