Banshee rebuild
Sacho87
and another tip of advice..... the guys on here will get pretty crabby if they see you making more than one post abou the same problem...... i know your problem is frustrating but we need a little bit of time to get through the basics about your bike. And 2 posts that are SUPER undescriptive are gonna make people real pissy around here.
and since your other post said it took a long time for you to get it started makes me think even more that you didn't put the choke tube back in place between the carbs...
Yea measured jugs and piston to make sure. Ok got it idle but it might be wrong I screwed idle screws in and it wasn't enough so I took the springs off and got it to idle that way will that hurt anything
Probably need those springs. They keep the screws from backing out.
If you have stock carbs, TORS removed, the surfaces where the springs seat need to filed. It is pretty straightforward, just be sure they are flat.
Read >HERE<.
