Throttle stuck
roesso
Went riding last weekend, second time at this place, throttle stuck both times. I had to smack the throttle real fast to get it to back off and the cable doesn't feel fraded and I don't have this problem around the house when riding. Any help would be greatly appreciated.
try to lubrificate the cable first
take it out riding again only make sure this time its a dry place and see if it does the same thing......then if you can.....find yourself somewhere semi-wet and try it there too and see if that's where your running into the problem. Like i said before......mikuni carbs are nutorious for binding up slightly when you run run em in wet conditions...
