dicedealer702 Posted February 21, 2011 Report Share Posted February 21, 2011 So I went to start my banshee for the first time to break it in. It took a few kicks,but when it turned it was stuck wot for about ten seconds untill I pulled the wires to shut it off. I hope It did not ruin any thing. I am sure the problem is in the carbs . I am kind of scared to start it agian Quote Link to comment Share on other sites More sharing options...
Phelps Posted February 21, 2011 Report Share Posted February 21, 2011 check your carb slides to make sure they are all the way down. either a cable not set right, or the slides are in backwards. Quote Link to comment Share on other sites More sharing options...
dicedealer702 Posted February 21, 2011 Author Report Share Posted February 21, 2011 check your carb slides to make sure they are all the way down. either a cable not set right, or the slides are in backwards. I moved the slides all the way down on both and also tried switching the slides. They are 35mm pwk so I don't think it matters which slide is in which carb Quote Link to comment Share on other sites More sharing options...
Jereme6655 Posted February 21, 2011 Report Share Posted February 21, 2011 is this a new build or a new never started before bike? Quote Link to comment Share on other sites More sharing options...
bansheedude55 Posted February 21, 2011 Report Share Posted February 21, 2011 do you have tors on it still? or the parking brake safety? do you have a line going from one carb to the other for the choke?! Quote Link to comment Share on other sites More sharing options...
dicedealer702 Posted February 22, 2011 Author Report Share Posted February 22, 2011 is this a new build or a new never started before bike? New build... I think the weather is differant from when I had itdyno last... To lean I think cause when I pull the chokes it helps a little Quote Link to comment Share on other sites More sharing options...
Jereme6655 Posted February 22, 2011 Report Share Posted February 22, 2011 yea sounds like your runnin really lean. Did you do a leakdown test on the motor before you started it? might have an air leak... Quote Link to comment Share on other sites More sharing options...
dirtydownunder Posted February 22, 2011 Report Share Posted February 22, 2011 as phelps said, make sure the slides are down, and when you flick the throttle you can hear them hit the base of the carb. wind all the idle screws out and same with the throttle cable at both ends so you have to give it throttle to get it to idle. then go from there. what inlet manifold are you using ? has the throttle cable been rerouted ? 10 seconds is a long time haha. Quote Link to comment Share on other sites More sharing options...
bansheesandrider Posted February 22, 2011 Report Share Posted February 22, 2011 do you have tors on it still? or the parking brake safety? do you have a line going from one carb to the other for the choke?! NONE of this applys, he has PWKs not the stock Mikunis. Quote Link to comment Share on other sites More sharing options...
12 0 Clock P I M P Posted February 22, 2011 Report Share Posted February 22, 2011 WAAAYYY TO LEAN......its called a run away....when your shit just revs out too lean.....richin that up about 7 jet sizes and start there...u need a big jump my friend Quote Link to comment Share on other sites More sharing options...
