LOTS of Banshee parts for sale......
I'm cleaning out the barn and want to sell this stuff, all prices are plus shipping. I'm posting some pictures, if you want a picture of something I don't have on here, send me a text and I can send it to you. 402-813-5312. I can also post more pictures on here, but will take me longer.
Stock j arm frame lightened and lengthened 6 inches with gold powdercoat, black and gold seat, and fullbore front plastic painted black with Trans Am bird. The pastic is clearcoated over the decals. The frame was modified very nicely, at first glace you hardly notice it's been lengthened. The radiator remains in the stock location, and the steering stem mount has been moved. The rear seat mount has been moved lower in the frame to bring the seat down. (it was set up that way to look better with no rear plastic) It's a really nice frame! $800 (seat, plastic, and frame)
one piece custom chrome steering stem/handlebars $115
banshee cases with no breaks $225 (have several)
banshee cases with chain damage, but still good $100
one thru five with stock neutral position $275
stock transmissions $80 (have several)
plus 8 swingarm, chrome round tube for no-link setup $300
stock swingarm with carrier $30 (have several)
stock swingarm without carrier $20 (have several)
aluminum AC swingarm skidplate $35
stock front bumper $20
stock grab bar with taillight $25
billet "tricklicks" shifter $25
black nickel plated Raptor axle $100 (never used since plating)
vito head nuts $5 (new in packaging)
38mm intake boots $50 (new in packaging)
complete electrical system with dyna box, stator, wiring harness, and coil. Has shift light and launch limiter. clutch lever and switch also included for launch limiter. $400
lightened stock a arm frame with steering stem and nice black powdercoat. $250
stock 1987 j arm frame with a title $125
front hubs with black powdercaot and good bearings and seals $60
lightened front hubs with green powdercoat, needs new bearings and seals $40
front hubs that need paint or powdercoat and bearings $30
V force 3 cages and reeds with spacers, very little use, $225
boysen reed cages with new petals $125
seat with metallic red cover, great condition $75
stock steering stem $35
rear shock with white spring in great shape $60
good shiftshaft $20 (have several)
stock cylinders, unported and need bored $300 (have several pairs)
stock 350 crank (trued and welded) $150 (have several)
lightened flywheel $125 (have several)
stock tie rods and ends (complete set) $25
chromed stock tie rods and ends (complete set) $45
stock intakes with boost bottle $20
complete stock clutch assembly, inner and outer hub, good fibers and steels, gear, bolts, springs $65
polished and shaved stock head $75
front calipers $40 pair (have several)
rear caliper $40 (have several)
master cylinder $20 (have several)
brake rotors, front or rear, $5 each (have several)
stock 6 stub sprocket hub $25
stock 4 stud sprocket hub with 41 tooth sprocket $25
stock 4 stud sprocket hub, powdercoated orange, with new 42 tooth sprocket and chrome nuts. never used. $35
rear brake rotor hub $20 (have several)
stock gas tank with cap and dual pingel valve $65
stock gas tank without cap $25
stock gas tank with cap $30
chrome grill $20
stock grill $5 (have several)
stock radiator cover with grill $20
kick starter shaft assembly $35 (have several)
chrome stock kickstarter $50
chrome stock spindles $60
stock spindles $30 (have several pairs)
stock radiator $40 (have several)
new in packaging complete gasket set $40 (have several)
chromed stock motor mounts (all 4) $65
stock rear hubs, powdercoated black $40
stock rear hubs $35
billet stator side engine cover $150
stock polished clutch side engine cover $80 (have several)
stock black clutch side engine cover $45 (have several)
stock foot pegs $25 (pair)
stock foot pegs, powdercoated yellow, never used. $35 (pair)
rear carrier bearings, new in packaging $40
a arm bearing kit, new in packaging $25 (does one a arm)
douglas blue label front wheels (10X6) $40 (pair)
douglas blue label rear wheels (8X8) $40 (pair)
chrome stock brake pedal with spring, washer, and c clip. $45
cylinder spacer plate $15
FMF fatty pipes (no silencers) $50 good shape but have been painted orange.
front Marvin Shaw shocks, 11 inches long. $250 (pair)
Hardkore engineering billet front hubs set up for raptor spindles with a honda bolt pattern. $80 (seals and bearings are good)
chrome grill $20
stock rear hubs $35
