Padla brats?
MacRacer1
STU (sand tires unlimited) makes some of the best tires around. I have a set of STU Sand Blaster 35's with a #2 cut on my long travel car. They're awesome, and even turning 100+mph, I don't worry about them seperating. Find out how many paddles they are, if they are 12's, I'd do the trade if they're in as good of condition, or equal to your current tires. I really like STU's.
Padla Brat
Application
The SAND TIRES UNLIMITED "BRAT" is a new addition to our impressive arsenal of sand tires. We designed and produce this tire as an ultra-light 4 ply drag racing and hill climbing tire that provides a radical bite-to-weight ratio. The tire has two paddle combinations, 6 or 9 paddles. Mounted on an aluminum wheel, the tire and wheel weight only 10-1/2 lbs, less than most other tires without a wheel. Without the sand throwing tendencies of many other tires, it is a good tire to follow. Recommended for 10" wide wheels for best tire profile, for ATV's as small as 200cc and the large ATV's up to the 500cc monsters.
  • Benefits
  • Durable & Rugged 4 ply construction
  • 20" height when mounted on a 10" wide wheel at 5 psi
  • Flexible grooving
  • 6 or 9 paddle design
  • 8" or 10" bead diameters
  • Tire weight (play grooved) - 9-1/2 lbs.
  • Tire weight (competition grooved) - 7-1/2 lbs.
From HERE
I don't believe they make a 12 paddle and they are very short.
