Steering stabilizer pic
andrew3160
Could anyone help me out and shoot me a picture of how they have their steering stabilizer mounted? Pref on a J arm frame but anything will help. I dont see how this thing will mount up with out looking rediculous. The stabilizer is a streamline.
Yep I figured it out. I put the mount on the other side of the frame but same way. Thanks for the pic
Do you have your radiator in the frame?? I ask because that's how i had mine till i put it in and then i couldn't get enough clearance between the shaft and radiator hose?
Rocz I would check and make sure that when your turned all the way to one side you won't hit your plastics. That was the the issue I was having. Nothing binds or rubs the way I have it pictured. You will have to bend the brake line mount out a bit.
